Problems with windows and lights
Old Jun 25, 2007 | 10:01 AM
spacecowboy's Avatar
I ordered LEDS from autolumination.com, got them last week, and went to replace the 164s with my new leds. I disconnected the battery and went to work. Super simple, took 5 mins if that. BUt now I have 2 issues.
1) the LEDs i put in the front doors and the rear lights shine when the car is on. it's faint, but i can see they are emitting some small amount of light
2) since i reconnected the battery, the one-touch up for the windows no longer works. one-touh down works, but up does not.
any ideas as what is going on?
Old Jun 25, 2007 | 12:34 PM
16 views... no one has any idea?
Old Jun 25, 2007 | 12:55 PM
Tiger's Avatar
I'll just reply with what I have read on this forum in the past:
1) the LEDs hold a certain amount of energy and glow for a while after the power source is disconnected.
2) You must complete the auto-initialize procedure for the auto up/down to work on the windows after disconnecting the battery. You can find it in the FAQ section. Basically, all windows must complete a full up-down cycle before the end points are re-learned.
Old Jun 25, 2007 | 01:24 PM
the one-touch down works just fine. it's only up. and i put the windows down and up, and they won't go up in one touch like they should.
Old Jun 25, 2007 | 01:34 PM
CalsonicVQ's Avatar
It's not a simple roll up and then roll down; you must hold the window switch for several seconds per the instructions. Just making sure you followed the instructions is all.
Old Jun 25, 2007 | 01:42 PM
can someone post a link to the faq? i'm at work, it's hard for me to do more than check my posts for replies. thanks in advance.
oh and i'll have to hold the button down when i get home tonight
Old Jun 25, 2007 | 06:26 PM
held the button, worked like a charm thanks guys
Old Jun 25, 2007 | 11:59 PM
shawnost's Avatar
LED's will typically require less drive voltage than a standard bulb, so when you replace the bulb with an LED it may/will turn on at a voltage that the bulb would not have. Do you have a spec sheet for the LED bulbs you bought, it should have this sort of info on it.
mike730
Jan 12, 2018 04:25 PM
leo38cheng
Nov 12, 2015 06:49 PM
wonderizm
Sep 24, 2015 03:09 AM
Lsantana757
Jul 20, 2015 09:08 AM
attarday
Jul 15, 2015 04:03 PM
