Can I change oil filter size?
Old Sep 9, 2007 | 02:23 PM
bruuster's Avatar
I just changed my oil myself (the removal of the plastic rock guard is a pain about 12 bolts ) and noticed that the oil filter is extremely small. Can I change to a larger one if the threads fit? there seems to be enough space there.
Bruce
Old Sep 9, 2007 | 02:26 PM
Nismo G's Avatar
Bruce
I am going to say yes - i have done it multiple times. I think i used a oil filter from a 4.0L VQ pathfinder and it is a little bit bigger. You will just have to put in that much more oil.
-Sean
Old Sep 10, 2007 | 10:39 AM
fecurtis's Avatar
If it fits, then go for it.
Old Sep 10, 2007 | 02:55 PM
Virus's Avatar
The only problem you may run into is the pressure it takes for the bypass valve. If it is higher than the smaller filter you could have a problem if it's needed.
Gookiecrunch
Aug 19, 2015 12:00 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
ClwMike
Jul 23, 2015 12:55 PM
justgotg35
Jul 19, 2015 12:33 PM
