Please Help Help Help!!!
Old Nov 4, 2007 | 07:15 PM
u4528010's Avatar
Is this the model? I think they mold that part upside down, it looks different from the picture in the instruction. It should be mold the the other side up.
SHORT RAM DUAL INTAKE WITH
DUAL FILTERS FOR INFINITI G35 2007
(306 HP MOTOR) SR-2205
Old Nov 4, 2007 | 08:19 PM
u4528010's Avatar
Are the holes in the same position as yours??
Attached Thumbnails Please Help Help Help!!!-1.jpg   Please Help Help Help!!!-2.jpg
Old Nov 4, 2007 | 08:23 PM
u4528010's Avatar
What I circled in red is where I believe the hole should be because it fits when I put the sensor facing the air flow filter
Old Nov 4, 2007 | 08:45 PM
B L U E S L A T E's Avatar
Honda Accord
Did you buy the correct intake? Isn't it for 350Z?
Or maybe you switched passenger side sensor with the driver's?
Old Nov 4, 2007 | 09:06 PM
u4528010's Avatar
I tried to swtich both sides. Still the same. The driver's side is fine.
Old Nov 4, 2007 | 09:32 PM
blindS!de's Avatar
2205 is the correct part #...
Here are some pics for you to match with what you have..
PASSEGER SIDE
DRIVER SIDE
Hope this helps... if it still doesn't work out, you might have gotten a defective one.. that happened to me before
Old Nov 4, 2007 | 10:15 PM
u4528010's Avatar
By judging from the pictures, I am 99% sure that I received a defective one
The length that I highlighted in the picture is different on mine, my is shorter. Thank you a lot for your help. May I use your pictures to show the seller?
Old Nov 4, 2007 | 10:35 PM
u4528010's Avatar
Hope this helps... if it still doesn't work out, you might have gotten a defective one.. that happened to me before[/QUOTE]
How did you get the new one? Return the defective one and ask for a new one? Honestly, I do not know how to explain this to the ebay seller, English is not my first language Thank you again
Old Nov 5, 2007 | 12:56 AM
Honda Accord
English is not my first language either, but you seem to be doing pretty well!
As far as what you'll need to explain to the seller, you can just tell the seller that you have received a defective intake and need it to be replaced. If they don't honor the return, you may be able to do something straight with the Fujita.
Best of luck.
Old Nov 5, 2007 | 12:58 AM
u4528010's Avatar
Best of luck.
Thank you very much I hope the seller understands my problem
Old Nov 5, 2007 | 03:11 AM
blindS!de's Avatar
How did you get the new one? Return the defective one and ask for a new one? Honestly, I do not know how to explain this to the ebay seller, English is not my first language Thank you again [/QUOTE]
It happened to my 4runner though, K&N took care of it eventhough i bought it off from a 3rd party.. as Fast07GSdn get fujita involved and have it replaced if the ebay seller doesn't do anything about it.. did you buy the intake from KURUMA motoring?
Old Nov 5, 2007 | 03:19 AM
u4528010's Avatar
It happened to my 4runner though, K&N took care of it eventhough i bought it off from a 3rd party.. as Fast07GSdn get fujita involved and have it replaced if the ebay seller doesn't do anything about it.. did you buy the intake from KURUMA motoring?[/QUOTE]
Thanks. I bought it from this seller
http://cgi.ebay.com/ebaymotors/FUJIT...spagenameZWD1V
Old Nov 6, 2007 | 01:04 AM
u4528010's Avatar
Thank you everyone for your helps. This is what the guy at Fujita emailed me.
"It does look like the sensor was welded on backwards. This would be a first as we have not had this problem before. I will send you a replacement pipe soon."
Old Nov 6, 2007 | 01:16 AM
Honda Accord
Good news! Glad things are working out fine...
