Sub/Amp install in 07 Sedan
Old 01-22-2008, 08:32 PM
stanfna's Avatar
We used Both at LOC & a line driver. I am not sure about the color of the wires & am unable to look in my car tonight...i'll get in there & look at it when i get a chance.
  #32
Old 01-22-2008, 08:47 PM
gymcshoe's Avatar
Thanks. Using the service manual I thought we tapped the right lines but it's not working. I look forward to your response. Thanks again
anyone else tap the wires before the bose amp? Can you tell me the color of the wires you tapped? Thanks
  #33
Old 01-22-2008, 09:53 PM
stanfna's Avatar
ok...you can thank my understanding girlfriend who will let me crawl around in my trunk taking pictures of wires and then talk about it online when i am supposed to be spending time with her.
but here is what i found. if you look at the picture where you can see the entire speaker (far left) you will see the red wire coming in from the right. this is the line we ran. we tapped into one of the red and one of the green wires going into the sub in the rear deck.
I hope this helps!!!!
Attached Thumbnails Sub/Amp install in 07 Sedan-img_3197.jpg   Sub/Amp install in 07 Sedan-img_3198.jpg   Sub/Amp install in 07 Sedan-img_3184.jpg
  #34
Old 01-22-2008, 10:46 PM
ON_6MT's Avatar
tap after the amp
heres a neat trick if you want to verify the right wires. Take your newly tapped wires, strip the ends and attach the - to the - end of a battery and the + to the + end of the battery. Speaker you are trying to tap will crackle. A simple AA works fine. If nothing comes out, your connections need to be checked.
Ps - i tapped the rear door speakers after the amp to get a L and R signal. I used a MTX 600.1 mono amp and I didnt use any LOC, just went staight from the taps to the amp. Worked great and the bass was clean and tremendously strong... untill i burnt another sub. I learned how to wire this car, next on the list proper tuning .... sigh
  #35
Old 01-25-2008, 10:22 PM
Bilaal Porter's Avatar
Originally Posted by gymcshoe
stanfna, did you use a LOC or line driver? do you know what color wires you tapped. I tapped wires before and after the bose amp and nothing is coming out of the amp/box.
gymcshoe,
Stanfna is correct, you want to tap after the amp, I have the bose wiring diagram for our cars. I tapped the wires that lead to the front door subwoofers (middle amp plug facing rear of car). These wires are the thicker ones RH(+)=green/RH(-)=red....LH(+)=black/LH(-)=white. I will be happy to send the audio diagram to your email, don't know how to do it through G35 driver. (8mb)- hope this helps
  #36
Old 01-25-2008, 10:37 PM
Originally Posted by shoeless
I don't think BP's system should cost very much. He only added a sub and mono amp.
evilMonkey,
I already had my amp from a previous set-up (fairly new), kicker sub= $149, Raamat sound deadening throughout= $140wood-fiberglass resin for sub box=$100, LOC= $75, power/signal cables+connectors= $72, labor= free, grand total around $536
  #37
Old 03-24-2008, 02:10 PM
kircher21's Avatar
For those of you who installed an amp, where did you find the best place to route the Positive wire from the battery? I'm about to tackle this task and this is the only thing holding me back. Thanks!
  #38
Old 03-24-2008, 04:57 PM
MiniRX7's Avatar
SOME POINTERS:
1. I have installed 0 gauge wire from the front to the back. The crappy part is getting it to come through but all you need to do is cut up the rubber grommet and then seal it up really good so it doesnt leak.. From there down teh passenger side panels, there is enough room to sneak 0 gauge or ANY GAUGE wire to the back!!
2. I have tapped my mono kicker amp BEFORE the BOSE SUB amp, not after, and I did not use a LINE CONVERTOR at all.
3. As with all CRAPPY BOSE stereos, the bass is really pumped at low volumes and then becomes more linear at high volumes, so for temporary i have installed a remote bass **** to adjust it with teh volume. When weather permits, i would go with something to clean up the signal (ie. MTX RE-Q, Cleansweep, etc)...
Hope that helps!!
  #39
Old 03-24-2008, 05:06 PM
kircher21's Avatar
Thanks! I'll check it out tonight
  #40
Old 01-25-2010, 02:13 PM
Austin713's Avatar
Im about to install my sub With a LOC and i found this Pinout in the Service manual. should be pretty helpful for tapping into the factory sub signal.
Attached Thumbnails Sub/Amp install in 07 Sedan-woofer-pinout.jpg
jsimonk
12-22-2023 03:49 PM
Jusseth
09-13-2020 12:25 PM
Mkhlmnn
V36 Brakes, Suspension, Wheels & Tires
08-01-2015 12:00 PM
joedaddy1
07-28-2015 02:58 PM
Thunderaan
07-22-2015 07:40 PM
Quick Reply: Sub/Amp install in 07 Sedan
