ICC Cutting off
Old Feb 25, 2008 | 01:19 PM
baileyt35's Avatar
ICC Cutting off
Halfway through a four hour trip my ICC cut off and would not come back on. It was quite annoying to say the least. Any TSB out on it?
Old Feb 25, 2008 | 02:31 PM
Stealthcords's Avatar
Is it possible ICC turns off automatically after 2 hours? Or was it raining?
I know an alarm beeps at 2 hours of driving in my Audi (doesn't have ICC) - it is a safety feature.
Old Feb 25, 2008 | 02:55 PM
baileyt35's Avatar
It was pouring down raining the whole ride. AND I did hear beeps which is wierd. I'm sure the quick fix would be to take a look at my manual, just haven't had time.
Old Feb 25, 2008 | 02:58 PM
snowcrossmxz's Avatar
were you driving into the sun and getting a LOT of solar glare on the front of the car? If you were, that will shut off the ICC. It uses a laser so it will get "blinded" so to speak if you get enough sun on the front of the car. It happens to me on my way to work a lot. It is also spec’d in the Manuel for this to happen. Wait till there is no more solar glare, and turn the cruse control off then on.
Old Feb 25, 2008 | 03:00 PM
oops didn’t read that it was raining. if the wipers are on full ( not intermittent) the ICC won't work. You can however use regular cruse control when it is raining.
Old Feb 25, 2008 | 03:05 PM
baileyt35's Avatar
Oh my, I really need to read my manual. The wipers were on full blast. But I had no idea you could use regular cruise control. How? I promise to read the manual before the year is out.
Old Feb 25, 2008 | 03:07 PM
i forget how to get regular cruse on, i "think" you hold down the on off button the the wheel and it will switch to regular cruse. "check the book"
Old Feb 25, 2008 | 03:14 PM
baileyt35's Avatar
hahaha, will do thanks again for the quick reference. I'm just glad I don't have to take the car in to the stealership.
Old Feb 25, 2008 | 03:15 PM
Lemodular's Avatar
You should avoid using the cruise control (manual or ICC) while driving in adverse weather.
Old Feb 25, 2008 | 03:29 PM
from the book
"To turn on the conventional (fixed speed)
cruise control mode, push and hold the
MAIN switch for longer than about 1.5
seconds."
the main switch is the on/off button on the wheel.
Old Feb 25, 2008 | 03:30 PM
G-Me's Avatar
/\ +10000 on that!
Old Feb 25, 2008 | 03:34 PM
baileyt35's Avatar
I never really thought about it but that is true, I shouldn't use it in adverse weather. It was storming really bad to. Thanks again everyone and thanks for the reference on regular cruise too!
Thebaws11
Jul 2, 2021 11:36 AM
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
JustinMKN1
Sep 18, 2015 03:40 PM
