How often should I get an A/C service on the car?
Old Mar 23, 2008 | 01:23 PM
NewGuyG35's Avatar
I live in a hot climate area, and you can't be driving around without the cooling system on. Since I drive everyday, I use it frequently. I was wondering how often I should get a service for it.
I'm assuming they just check for any leaks and stuff like that, and don't replace the freon that has been used?
Old Mar 23, 2008 | 04:18 PM
rpm&my_G35's Avatar
These guys have a descent write up on it...http://teamvalleylandrover.co.uk/pag...ng-service.php
To summarize...if nothing is noticeably wrong...about every 3 years.
Old Mar 24, 2008 | 03:51 PM
max2k1's Avatar
In a closed-loop cooling system (like the car A/C), the refrigerant(what you call Freon even though its no longer used) should not get "used" up at all -- you don't spend the refrigerant.
champppy
Mar 31, 2020 12:25 PM
Rehman2009
Jul 27, 2015 03:23 AM
ClwMike
Jul 23, 2015 12:55 PM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
mjfenix
Jul 17, 2015 02:07 PM
