Is speedometer reading for 07+ Sedan: Frt or RR?
Old May 22, 2008 | 05:10 PM
EWG35's Avatar
Does anyone know for sure if Speedometer readings are taken from the Front or Rear wheels? I have been told it's the rears. I need to take that into account when buying new tires.
Old May 22, 2008 | 10:17 PM
EnviedG35's Avatar
Go in a wet parking lot, take of vdc and spin the tires, if the speedometer moves then its the rear, if not, its the fronts haha
Old May 23, 2008 | 08:35 AM
snowcrossmxz's Avatar
^^ I did that in the snow, the spedo is taken from the trany, so if u have a rwd car then its taken from the rear, if you have a FWD car, then its taken from the front. its like that on ALL cars.
Old May 23, 2008 | 02:18 PM
chilibowl's Avatar
Which one? The "trany" or the front or the rear?
Old May 23, 2008 | 02:27 PM
G35Now!'s Avatar
Moderation-free
Didn't he answer? You have RWD, so the tranny will show the speed of the rear wheels...?
Old May 23, 2008 | 10:23 PM
EWG35's Avatar
Thanks Bro. I thought it was the rear but I never knew the transmission had anything to do with it. Makes sense.
Old May 25, 2008 | 09:00 PM
ya, its the forward output shaft, thats y it doesn't take miles off when you back up.
Old May 25, 2008 | 09:08 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
It doesn't..
Speed pickup is from sensors on the rear stub axles after the rear differential.
Old May 26, 2008 | 04:50 PM
07-G35-MT/S's Avatar
Originally Posted by InTgr8r
It doesn't..
Does this mean if you change to a different gear ratio, the speedo is still true?
Marlin84
Apr 1, 2020 12:52 PM
KallDay86
Jan 8, 2016 12:42 AM
AL8782
Oct 3, 2015 10:26 AM
NyCrAzY
Oct 1, 2015 09:19 AM
Learned Hand
Oct 1, 2015 09:02 AM
