I was suppose to get an oil change 150 miles ago..
Old May 28, 2008 | 10:44 PM
NewGuyG35's Avatar
Hello. My car is in need of an oil change. I was suppose to get it about 150 miles ago but will not be able to until Friday, which will probably added another 200 or so. Is it ok to wait this long for oil changes? I usually get them with 50 to 100 miles before the mile thingy on the sticker but have not had time.
Old May 28, 2008 | 10:45 PM
express705's Avatar
you will be fine.
JOKER's Avatar
CLUB MODERATOR
how often do you change your oil?
Old May 28, 2008 | 10:46 PM
WaLLy's Avatar
Old May 28, 2008 | 11:41 PM
Pie-rat's Avatar
Is this even a serious thread? Some people go 6-7k miles between oil changes... its not reccomended, but 200 miles is nothing
Old May 28, 2008 | 11:43 PM
JOKER's Avatar
CLUB MODERATOR
Bimmer recommends 15k
Old May 29, 2008 | 12:48 AM
NewGuyG35's Avatar
Like I said, I usually change it with 100 to 200 miles before the due date. I'm just high maintenance with the cawr.
Old May 29, 2008 | 02:05 AM
JOKER's Avatar
CLUB MODERATOR
So
how often is that?
Old May 29, 2008 | 02:15 AM
jsmonet's Avatar
Originally Posted by JOKER
So
how often is that?
3750-200=3550 on the dot.
just figure he's changing his oil every 3k to 3500 miles. we're not using precise numbers here, as anything within 1k miles is fair game and not a big deal at all
Old May 29, 2008 | 03:34 PM
silverG2007's Avatar
Actually, 7500 miles is recommended.
I use full synthetic and go 7500 no problem. Just use a good oil filter.
But, "miles" is only a recomendation. If you drive 2000 miles a year and they're all city..... I'd change the oil at 2000 miles. Hwy vs. City and time all matter. What oil and filter you use matter too.
Old May 29, 2008 | 03:40 PM
LiquidGx's Avatar
This guy has 500+ post, this thread is a joke.
Old May 29, 2008 | 03:45 PM
SDGeneralCounsel's Avatar
What full synthetic do you use? There are really only two oils that are actually "full synthetic". You should change your oil every three months, or after you have exceeded the recommended miles on the oil. Wow this thread is just wow lol.
Old May 29, 2008 | 04:20 PM
BlueDevilBAMF's Avatar
I think we need an IP check on NewGuyG35...
Old May 29, 2008 | 05:41 PM
Wei's Avatar
Wei
reg fram filter blows
it's the only one that has failed from all the different types of filter I've used over the years
Old May 29, 2008 | 06:11 PM
nghiars's Avatar
fram is as cheap as china filters....
Owners manual says to change aroun 7500/3 months if you do mostly highway and 3750/3 months if mostly driven in stop and go or short distance driving where your car has not fully warmed up.
