Wheel Fitment questions
Old Jul 3, 2008 | 05:30 PM
CantSeeMe-G's Avatar
Question Wheel Fitment questions
Some guy is selling a set of 20" rims, 9" wide in the front, 10" in the back, with Yoko AVS ES100 245/35 + 275/30. tires, Will these fit on my 08 sedan without any rubbing? also will dropping it make a difference?
any help is greatly appreciated... thanks
edit: offset is 25+ all around, not sure if im gona lower it or not, depends on how it looks, or which way itl fit better.
Old Jul 3, 2008 | 05:38 PM
Wei's Avatar
Wei
need to know the offsets, and need to know if you're planning to lower it, makes all the difference
Old Jul 3, 2008 | 05:44 PM
25+ all around
Old Jul 3, 2008 | 06:48 PM
Wei's Avatar
Wei
def need to lower and camber it out,
my opinion, the 275's in the rear most likely will rub
Old Jul 3, 2008 | 09:34 PM
Pie-rat's Avatar
with +25 offset they are going to be WAY outside the wheel well. Rear will probably be okay, but the front is where you may run into some rubbin!
Old Jul 3, 2008 | 10:12 PM
heyitsalex's Avatar
fronts will actually sit FLUSH!!! The rears will stick out about 15mm. Go +35 in the rear.
Old Jul 4, 2008 | 09:21 PM
Borna's Avatar
Fronts would need quite a bit of negative camber and the rears would rub.
I think a nice balance between an agressive look and practicality would be 8.5" +30 and 10" +40. Any opinions on this?
Old Jul 5, 2008 | 03:10 AM
heyitsalex's Avatar
^^ +1000
Old Jul 5, 2008 | 04:23 AM
Borna's Avatar
^ can you post a pic of your car from before and after you installed the spacers? That's almost the exact specs I was talking about
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
joedaddy1
Jul 28, 2015 02:58 PM
Detailed Image
Jul 24, 2015 12:31 PM
Soumilg
Jul 18, 2015 12:33 PM
