How to Remove Keyhole Cover
Old Jul 4, 2008 | 01:11 PM
simpson's Avatar
^^^the same way^^^
Old Jul 5, 2008 | 11:35 AM
stanfna's Avatar
I followed the instructions here...
https://g35driver.com/forums/questionable-posts/184877-diy-drivers-side-door-key-hole-cover.html
no scratches & i did not break the old piece.
Old Jul 5, 2008 | 04:20 PM
kmuniz78's Avatar
I suppose anyway will work.
Old Jul 6, 2008 | 12:32 AM
markk132's Avatar
ok, time to shoot mike at riverside a PM and order this bad boy
Old Jul 12, 2008 | 06:37 PM
kmuniz78's Avatar
You won't be disappointed! Easy, and great looking when completed!
Old Jan 8, 2010 | 09:23 PM
bat6wc's Avatar
Originally Posted by kmuniz78
SWEET! Thanks!
Instructions for removing driver's side keyhole cover; Give a real clean look:
1st - Locate the black cap on the inside of the driver's door (see pic)
Attachment 92497
2nd - Pop off cap; locate hex screw; difficult I know:
Attachment 92498
3rd - Use 5/32" hex rench to unscrew bolt (won't fall into door; has a saftey lip)
Attachment 92499
4th - Pop off keyhole cover (forgot to take pic); replace with new cover (also forgot to take pic)! Should look like this when done:
Attachment 92500
does that cap on the side of the door just pry off from the edges?
Old Jan 8, 2010 | 09:31 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Yes, it just pops off, you don't need to do it like this thread.
Check the DIY section, there's a thread in there
https://g35driver.com/forums/v36-diy...ole-cover.html
Old Jan 8, 2010 | 09:34 PM
bat6wc's Avatar
yes i know about that method but I want to do it the right way so I dont scratch anything. i am talking about the cap on the side of the door, not the actual keyhole cover.
Old Jan 8, 2010 | 09:35 PM
speedracerg35's Avatar
when you get the pictured clip undone, make sure to slide the cap off towards the rear of the car. there are two little tabs at the back of the cover that hold it onto the mount.
Old Jan 8, 2010 | 09:36 PM
InTgr8r's Avatar
^ good point.
Old Jan 9, 2010 | 06:02 PM
bat6wc's Avatar
just did the install...was very easy.
unfortunately, when i was tightening the bolt on the side, my hand stopped working and i dropped the allen key down the door!
i have a magnetic snake I am going to try, if not, i guess teh door panel has to come off.
Old Jan 13, 2010 | 10:25 PM
^this is why you do it the easy way, from the outside.
Old Jan 13, 2010 | 10:26 PM
bat6wc's Avatar
haha, i know! now i know I can do it the easy way without scratching.
its still in my door and rattles like a b*tch. The door panel is coming off tomorrow. Just hoping I can access it with the panel off.
Old Jan 14, 2010 | 12:50 PM
bat6wc's Avatar
alright, just took the door panel off and got the wrench out!!
took me about 45min-hour to take off the panel and put back on. Actually very easy compared to other door panels i have taken off.
Danielek
May 1, 2022 01:28 PM
Thebaws11
Nov 30, 2016 12:54 PM
JG_G35
Apr 29, 2016 04:46 AM
junon
Sep 5, 2015 10:40 PM
