How to Remove Keyhole Cover
Old Jul 4, 2008 | 11:23 AM
kmuniz78's Avatar
I bought a replacement keyhole cover. Question. How the heck do I pop off this piece:
I know, I know, it's a piece of cake. Well, I'm slightly retarded. So, please help.
Many Thanks!!!!
Old Jul 4, 2008 | 11:29 AM
simpson's Avatar
i have not worked on any g35 but i think on the inside of the door there is a round cover that you pop off. inside the cover you will find you can see the other side of the handle. you will unscrew the torks head screw and the cover will pop out when you unscrew it all the way. the screw will not fall out because it has a holder for it so dont try and pull it out
Old Jul 4, 2008 | 11:30 AM
kmuniz78's Avatar
I'll try it now. Thanks!
Old Jul 4, 2008 | 11:42 AM
speedracerg35's Avatar
no ! pull the door handle like you are opening the door and you will see where the cover clips on to the bracket. use a pick tool to release the clip, pull towards you and towards the back of the car at the same time.
Old Jul 4, 2008 | 11:45 AM
simpson's Avatar
i did not think that you could take just the cover off with out breaking it. it clips under and would scrach the car if it pops off
Old Jul 4, 2008 | 11:54 AM
there is a diy w/pics on myg37. it takes a total of 20 seconds to do. i dont think anyone has scratched their paint doing this. use a bunched up towel shoved between the handle and the door to leep the door lever pulled open. this way, you can use both hands to get this done.
Old Jul 4, 2008 | 12:00 PM
simpson's Avatar
got you at work i have to take them out all the time so they can paint the car. but i have never just needed to take the cover off
Old Jul 4, 2008 | 12:06 PM
what shop do you work at?
Old Jul 4, 2008 | 12:13 PM
simpson's Avatar
purnells in elkton md
Old Jul 4, 2008 | 12:19 PM
kmuniz78's Avatar
SWEET! Thanks!
Instructions for removing driver's side keyhole cover; Give a real clean look:
1st - Locate the black cap on the inside of the driver's door (see pic)
2nd - Pop off cap; locate hex screw; difficult I know:
3rd - Use 5/32" hex rench to unscrew bolt (won't fall into door; has a saftey lip)
4th - Pop off keyhole cover (forgot to take pic); replace with new cover (also forgot to take pic)! Should look like this when done:
Old Jul 4, 2008 | 12:22 PM
kmuniz78's Avatar
Yeah, I tried to just pop the cover off after lifting the handle; pretty hard to do. Didn't want to break anything. This way was slightly more work, but took all but 10min (tops). Much easier to pull the old cover out, pop it off, the put the new one on. Either way, easy mod after thinking about it! Thanks again simpson!
Old Jul 4, 2008 | 12:30 PM
i used to own a.c.e.s. body and paint works in white marsh. we did a lot of custom work for some of the local car clubs.
Old Jul 4, 2008 | 12:40 PM
RobDiesel22's Avatar
whered you get the key cover?
Old Jul 4, 2008 | 12:48 PM
terrycs's Avatar
Damn ... wish I knew about that bolt! I'm one of the unlucky ones that scratched my car (not too bad though)!
Originally Posted by kmuniz78
SWEET! Thanks!
Attachment 92497
Attachment 92498
Attachment 92499
Attachment 92500
Old Jul 4, 2008 | 01:09 PM
O HELLA OEM's Avatar
sry for going a bit offtopic ..i kno theres a DIY for the G35 coupe but some of the pics are gone..i was wondering if any knows how to install the keyhole cover for a G35
