Sound when the AC running
Old Aug 5, 2008 | 11:42 AM
08g35s's Avatar
Did anyone experience this? I get a sound like boiling water from AC system. When I stop at signal or going at lower speeds, I can clearly hear that sound.
The not that high, but its little annoying.
Old Aug 5, 2008 | 01:06 PM
ugaexploder's Avatar
never heard this before.....there is a thread on here about the steering fluid boiling though
Old Aug 5, 2008 | 04:43 PM
J2S2M's Avatar
I also hear some buzz sorta sounds occasionally when the AC in running.
Old Aug 5, 2008 | 05:05 PM
You might need to get the TSB done on your vehicle and remove the silicon pieces out of your AC system if you're hearing buzzing noises........
Old Aug 5, 2008 | 05:30 PM
truzaro23's Avatar
yup i have the same noise when my ac is on...im planning on getting that checked during my next service..
Old Aug 8, 2008 | 08:17 AM
AesonVirus's Avatar
Anyone got this TSB # handy?
Old Aug 8, 2008 | 09:59 AM
PM me your email adress and I'll have attach the PDF for ya
Old Aug 8, 2008 | 10:23 PM
EWG35's Avatar
Mine has that problem. My 07 was in for a coolant leak, which they did not fix. I'm taking it back in on Tuesday and learned from Infiniti Customer Service there is an AC fan recall. They will be replacing mine on Tuesday. At least I hope they are capable of fixing it.
Old Aug 9, 2008 | 12:20 PM
jsmonet's Avatar
boiling sound behind the dash? old school knowledge says your cooling system has an air bubble in it and needs to get burped a little
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
derres
Aug 28, 2015 03:27 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
Wayne9011
Jul 27, 2015 11:25 AM
006
Intake & Exhaust
Jul 19, 2015 04:30 PM
