Intelligent Key battery and memory
Old Sep 4, 2008 | 02:37 PM
bigern79's Avatar
Question Intelligent Key battery and memory
I'm getting the warning message that my I-key battery is low and needs replacement. I'm worried that by doing so, it will "forget" my seat/mirror settings. Can anyone validate if this is an issue (albeit, extremely tiny issue)? I know, I know, it's probably in the manual, but I'm lazy like everyone else.
Old Sep 4, 2008 | 03:17 PM
Coach's Avatar
The settings are stored in the BCM, not the fob.
Even if the settings were stored in the fob it's not like you have a choice, if you don't change the battery out it will eventually be dead, with the same result.
Old Sep 4, 2008 | 04:19 PM
boss81's Avatar
What's the warning you get when the I-key battery is about to die?
Old Sep 4, 2008 | 05:07 PM
DigMy35x's Avatar
I just replaced the battery in my M key fobs right before I returned it for my new G lease. (Murphy's law timing!).
It was SUPER easy and it does not change any of the memory settings. Just be careful when you start to pry it apart. The plastic can be pretty brittle on the top and it's easy to take off a small chunk if you don't go easy.
But again - very simple process. I just did both at the same time since I got a 2 pack of batteries for pretty cheap.
Jay
Old Sep 4, 2008 | 05:31 PM
coolguy8157's Avatar
I'm not sure about the G but on the FX which I had before....whenever you start the car the I-Key sign on the dash will be lit for about 30 sec or so.....this means that that I-Key battery is low...I did replace mine on the FX and the sign went off .... I presume the same here
Old Sep 4, 2008 | 06:08 PM
G35Now!'s Avatar
Moderation-free
+1 Your settings are safe. As someone else said, just take the metal key out of the iKey, and pry it apart. I usually use a sharp knife.
Old Sep 4, 2008 | 07:40 PM
AesonVirus's Avatar
The memory is stored in the car, not in the fob.
Also, if you are that concerned, make sure your seat, wheel, mirrors and radio are all set as you wish and then replace the battery without making changes.
Worse case scenario, you hit the memory button in the car again to set everything... but it's not going to be an issue.
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
