xenon lifespan and replacement cost
Old Oct 6, 2008 | 09:53 PM
greg_atlanta's Avatar
2008 G35 Journey Sedan no sunroof
Question xenon lifespan and replacement cost
Am I the only one who's afraid to use my headlights? I'm worried about the "frequent on/off operation" so I don't use the auto setting, and I rarely turn on the headlights inside a parking garage.
So.... how long can I expect the bulbs to last under normal use? (not on auto setting)
When they do burn out, what can I expect to pay the dealer to replace them? Is it an easy DIY job if I buy my own bulbs? Do the bulbs need to be replaced in pairs?
I searched and found a lot of stuff about aftermarket, but I'm happy with OEM setup so far.
Old Oct 6, 2008 | 10:03 PM
EnviedG35's Avatar
You can adjust the sensitivity for the auto headlights. I leave mine on auto all the time and they only turn on when its actually dark or im in a parking garage. Xenons can last longer than your car. I wouldnt worry about them going out. It can happen as they are an electrical item, but even if they do you can get oem replacements on ebay for less than $100 a pair.
Old Oct 6, 2008 | 10:40 PM
G35Now!'s Avatar
Moderation-free
I had Xenons in my Maxima, and left the lights on Auto all the time. It's a 2003, and the Xenons are still fine (my sis-in-law bought it).
Old Oct 6, 2008 | 11:22 PM
TakeFlight's Avatar
I've read in the past that you could expect your xenons to last 10 years or longer. I traded in my 6 year old 03 G35 (for a 08 G35x) a little over a month ago with perfectly working original xenons and I always used Auto.
This is definitely not something to worry about.
Old Oct 7, 2008 | 02:43 PM
carz's Avatar
question: are they covered under warranty?
Old Oct 7, 2008 | 04:19 PM
Thanks... I just found that in the menu and adjusted it. My apt has a small parking garage, so that's a lot of unnecessary on/off to come and go each day, but I guess I shouldn't worry about it.
Old Oct 7, 2008 | 05:14 PM
TakeFlight's Avatar
I park my car in my garage and every day when I leave for work the headlights turn on with the car and then turn back off a few seconds later when I pull out of my garage. I did this for 5 of the 6 years I owned my old 03 G35 before trading it in. Sure, anything can fail. But I don't believe this is an item to be worried about.
Old Oct 7, 2008 | 07:13 PM
mIKE's Avatar
For a (very) short duration, yes. If they're defective, they'll already be broken by the time you buy your car. Xenon lights should last a very long time, as Nissan/Infiniti uses a high quality ballast.
Old Oct 7, 2008 | 11:58 PM
Wes_888's Avatar
it'll cost you to replace them though... not talking about the cost of the bulb but the cost at the dealers to replace em for ya... 1-2 hrs work.. which is 100-200 bucks!! ACK!
so good thing its good quality xenon lights!!!
Im in the process of replacing my fog lights right now.. and out of curiosity I phoned the dealer and asked them how much it will cost for them to install it.. and thats what I got. Hence... im doing it myself.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
chinee
Aug 8, 2015 10:11 AM
Karl_g335x
Aug 3, 2015 03:43 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
