Big Problem
Old Nov 16, 2008 | 12:53 AM
titan13qb's Avatar
Big Problem
So my sun/moon roof won't close and I don't know why...
I pressed the button to send it back so I could get some fresh air, and it went back normally. Then I pressed it forward to get it to shut, but it went too far forward. It is in the position for "smokers"...where it is tilted upwards and everytime I press the button for it to shut it does nothing...
Any Ideas how to fixx it, b/c it is already below freezing and I dont have a garage to pull into at the moment...
Thanks ahead of time
Chris Cary
Old Nov 16, 2008 | 12:53 PM
bfranks's Avatar
Just to cover all the bases, did you try to hit the open button (since this is actually how you close it from that tilted up position). If so, then look on page 2-52 in the owners manual for a way to reset the sunroof. Hopefully that will work for you.
Edit: That page is for 08 models, so yours will probably be different.
Old Nov 16, 2008 | 01:30 PM
titan13qb's Avatar
that didnt work unfortunately...i guess just take it to the dealer
Old Nov 16, 2008 | 01:31 PM
bfranks's Avatar
Is it moving at all (can you hear the motor)? If not you might check the fuse. That sucks, especially since you can't get it out of the weather.
Old Nov 18, 2008 | 12:08 AM
titan13qb's Avatar
its not moving just making the noise...trying to get a date to set an aptmnt w/ the dealer but kinda busy...i still cant wash my car and hose it off cause its open....ahhh its driving me crazy
Old Nov 18, 2008 | 10:30 AM
tateinaz's Avatar
Mine did the same thing...screw came loose. Had to go to the dealer for an oil change and they fixed it in a few minutes.
Old Nov 18, 2008 | 10:36 AM
STCLAIRWEST's Avatar
it probaly got derailed
Drifter2090
Dec 26, 2015 12:10 AM
Mick_L
Aug 25, 2015 04:27 PM
Phenomenon9
Aug 9, 2015 01:34 AM
