Synthetic Oil
Old Nov 26, 2008 | 12:06 PM
Rizzagt22's Avatar
Synthetic Oil
Hey guys,
I am approaching my 5th oil change at 18,750 miles. What kind/brand of synthetic oils do you guys use in your 07+ G35 Sedans?
Old Nov 26, 2008 | 12:10 PM
paulg35s's Avatar
I use Castrol Syntec.
I used Mobil 1, Valvoline, etc. I seem to have the best results with Castrol.
Old Nov 26, 2008 | 12:16 PM
dohturdima's Avatar
I just put in Pennzoil Platinum 5W-30. There is a lot of debate regarding different types of synthetic oils.. some swear by some (i.e. work better in VQ engine), others by others (experience, anecdotal evidence) - but IMO the differences aren't hugely significant between the better known brands. Mobil 1, Castrol Syntec, Amsoil, Valvoline, Pennzoil and even Quaker State synthetic are all better than conventional.
Old Nov 26, 2008 | 12:19 PM
Cabad85's Avatar
Mobil 1 0W-40
Old Nov 26, 2008 | 12:22 PM
ANMVQ's Avatar
I always use Mobil 1, But I used to use Castrol. I use Mobil now cause my buddy always has it in stock, If had to order it a may use Castrol. I used castrol in my 650hp street/drag car and never had a issue..
Old Nov 26, 2008 | 09:02 PM
sredish's Avatar
Royal Purple 5w40 synthetic, all the way.
Old Nov 26, 2008 | 09:16 PM
Polo08816's Avatar
+1.
The Pep Boys deal of 5 qts of PP 5w-30 + 1 PureONe filter for $27 is a pretty good deal.
I think as long as you're using synthetic grade oil for a naturally aspirated engine it doesn't matter too much.
Oil quality may come into play if you are turbocharged. I have a 08 Legacy 2.5GT and from the Legacy forums, the engine is more sensitive to oil based on Used Oil Analyses. Those who have sent their oil in to be analyzed say that M1 5w-30 instantly shears down to a 5w-20 and does not provide adequate protection in a turbocharged engine (due to heat). They recommended M1 0w-40. M1 tends to be a thinner oil. PP is a thicker oil and doesn't shear down to a 20w.
I'm sure this won't be a problem in the VQ35HR. It seems to be okay to go up 1 level of viscosity in engines though. 0w-40 or a 5w-40 is okay to use.
Old Nov 28, 2008 | 08:00 PM
geronimomoe's Avatar
Originally Posted by Rizzagt22
Hey guys,
I used M1 5w-30 at my first oil change, at roughly 2400 miles. Today, at 6400 miles I put in Castrol Syntec 0w-30 (GC).
Old Nov 28, 2008 | 08:29 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I've used Amsoil with great results (sample testing) for many years.
....just in the process of restocking.
- ASL 5W-30 for the engine.
- MTG 75W-90 for the 6MT
- SVG 75W-90 for the rear diff.
Old Nov 28, 2008 | 08:33 PM
gary c's Avatar
You could have changed to synthetic oil long time ago. I've been using
Mobil 1 for years without any issues. WallMart sells Mobil 1 at a resonable
price. As long as you're going first class don't forget to use their oil filters
too.
Gary
Old Nov 28, 2008 | 10:46 PM
Swivel's Avatar
Moderator
Since I'm a dealer, of course I use the Amsoil ASL 5W-30, and will be going with the gear lube for my diff soon.
Old Nov 28, 2008 | 11:50 PM
Extreme G's Avatar
When you change your oil to synthetic , Do you have to put a synthetic blend first or can i just put straight synthetic oil.
Old Nov 28, 2008 | 11:55 PM
fluffy's Avatar
i've taken all my cars to synthetic no matter age or mileage, no problems so far....
Old Nov 29, 2008 | 04:01 AM
Swivel's Avatar
Moderator
Go straight to full synthetic, no transition oil is required. And use a good quality oil filter like a Wix or Amsoil, not a Fram.
Old Nov 29, 2008 | 01:47 PM
Extreme G's Avatar
thank you .
