strange issue when filling up
for the last couple of times filling up at the pump..
my needle on the fuel tank gauge will not point to the very top line.. it stops at the line below the top..
when i try to put in more gas.. the pump will not let me since it should be full..
i have tried filling up at two different gas stations and this still happens
the last time, i force pumped more gas into the tank and gas overflowed
so the tank has to be full
usually when i fill up, the needle will be above the top line
anyone have this issue?
so the tank has to be fullusually when i fill up, the needle will be above the top line
yeah, i will bring the issue up when i get my car serviced.
the strange thing is.. after driving like 25+ miles.. the needle moved up past the top line..
i bet the float or float arm in the tank is messed up
thanks for replies!
thanks for replies!
All G'd Up
Aug 29, 2015 12:40 AM
