How do I open the the plastic snap on the side to run wire
Old Mar 7, 2009 | 08:02 PM
vietkool's Avatar
I plan to run power from the battery to the back truck supply for the bazooka amp. question is how do I open the plastic snapped on the side (driver side) so I can run the power wire under the carpet all the way from battery to the back trunk. I done one time on my old accura.there are fews crews to take off then I can take the side panel off. but my infiniti does not have screw. thye may use the snap on clips or somethings.
is any1 done this please help me.
thanks
Old Mar 7, 2009 | 08:30 PM
AesonVirus's Avatar
If you're talking about the plastic trim that runs along the bottom interior trim, it just pops off and back on again... no screws.
Old Mar 7, 2009 | 08:52 PM
vietkool's Avatar
which tool should I use to pop them off the frame? I try my hand but so hard to grip and get the fingers to lift them up
Old Mar 7, 2009 | 09:47 PM
E-Ticket Ride's Avatar
Get a panel puller, or one of those plastic panel tools (the thin one, about 1/3" wide)
Old Mar 7, 2009 | 11:25 PM
AesonVirus's Avatar
If we are in fact talking about the same piece of trim work, (The long plastic pieces next to the kick plates and the seats) I'm able to just pop them off with my hands.
Old Mar 8, 2009 | 03:14 AM
kool_yaar's Avatar
^+1 the white little long tabs can easily be pulled off the frame by pulling out and up.
Old Mar 8, 2009 | 07:25 PM
vietkool's Avatar
thanks guys, took me 2hrs to run a power cable from battery to the back trunk and a remote wire . Hooke to the 8" bazooka with built-in AMP, it's just a little bit more bass than the stock one but not much. The bass came out kindda hard. I am looking for 10" now.
Muski_G
Dec 1, 2023 11:11 AM
EnCr1pt3d
Jul 8, 2019 02:48 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
wylin
Lights
Jul 18, 2015 06:12 PM
