Battery Acid? Help!
Old May 19, 2009 | 09:19 PM
popcornten's Avatar
Battery Acid? Help!
Ok so I installed 8000K bulbs yesterday, took off the negative terminal and everything seemed fine. I went again today to take off the terminal to adjust one of the bulbs and there's a pink residue on both the + and - terminals. It was on the little nubs and the metal rings that get connected.
I brought the car in for service between yesterday and today. I have a Grounding Kit and the 8000K bulbs. Should I just wipe it clean as much as I can or is this an issue?
Old May 20, 2009 | 08:29 AM
snowcrossmxz's Avatar
its not an issue, its very common,
u can have the dealer clean it for a small fee, $30 or so, or do it ur self.
you can get some bat terminal cleaner at autozone,
or just mix baking soda and water 50/50 and put it on the contacts, it will dissolve the pink stuff,
take apart the terminals and clean them with a brush and the baking soda solution. and then put back together.
here is a more in depth description of the same thing
http://www.ehow.com/how_4487461_clea...ls-baking.html
Old May 20, 2009 | 08:52 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
^WHS
After you clean them up use a little grease to seal them up
& it will help prevent the problem.
Old May 20, 2009 | 08:53 AM
tg1234's Avatar
After it is cleaned you can use a spray. Can't recall what's called. It is basically puts a clear coat on electric conectors and keep the contact 100% or close to it. Can't corrode.
EDIT
Got in the garage and checked it.
Called "Off Guard" Electric clear coat spray. Works magic. I use it all the time when I work on electrical parts.
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Thebaws11
Nov 30, 2016 12:54 PM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
