Washer Nozzle Adjustment?
Old Sep 15, 2009 | 08:49 PM
mikeb2's Avatar
Are the washer nozzles adjustable? Mine are hitting a bit low on the windshield and they could be doing a better job if they were aimed better. I gave them a quick look and didn't see anything obvious. Fortunately, I walked away before I had a chance to break anything.
Thanks...
Mike
2007 G35x
Old Sep 15, 2009 | 11:04 PM
Q8y_drifter's Avatar
make sure they're clean cause sometimes that will mess up the water spray direction.
Old Sep 15, 2009 | 11:08 PM
GLuXuRy's Avatar
if adjustment is needed .. dont quote me on this but the way we adjust BMW washer jets is by using a small pick (like the tool dentist use to clean your teeth) .. not entirely sure if ours are adjustable, never tried it, but i would assume you could
Old Sep 16, 2009 | 12:42 PM
kregg's Avatar
Yes it is adjustable. i had the same problem with mine. See post #141 here:
https://g35driver.com/forums/g35-37-...ml#post4213348
Old Sep 16, 2009 | 08:30 PM
mikeb2's Avatar
Ahhh..thank you. I thought I had seen that somewhere but couldn't find it.
Mike
Old Sep 17, 2009 | 01:19 PM
kregg's Avatar
NP, I am a wealth of worthless information, lol Glad someone might get use out of it
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
Fox843
Nov 7, 2015 05:43 PM
master111
Sep 25, 2015 08:32 PM
blueslatebenny
Sep 23, 2015 01:39 PM
