Maintenance
Old Jan 15, 2010 | 01:52 PM
A. B. Hair's Avatar
Question Maintenance
My wife has an 08 G-35 that is about ready for the second oil change. I do my own regular maintence. I find the under engine cover very hard to remove and some of the clips break and can't be replaced. Does anyone have a better way and have better replacement clips? thanks, need help!
Old Jan 15, 2010 | 01:55 PM
elayman's Avatar
the clips should be fairly simple to remove with a flat head screwdriver. just fit it in the groove and pop the head out and then remove.. but yes they do break easily. The dealer sells them at a ridiculous price but you can probably find them on ebay or something. To do an oil change on my coupe, you don't really have to remove the whole undercover (I'm not sure about the sedan) have you tried just bending it back once you removed some of the rear bolts?
Old Jan 15, 2010 | 02:04 PM
A. B. Hair's Avatar
To Elayman: No, I removed the entire cover. I'll try removing the rear bolts. I wonder if some type picture hanger screw that expands when tightened would work and could be removed easley. Any one tried another type clip?
Old Jan 16, 2010 | 04:58 PM
kool_yaar's Avatar
i think the Journey and X have a separate door in the splash shield for the oil change while the S cover has to be removed to do the oil change properly and easily, not that hard really with an electronic 24v driver
Old Jan 17, 2010 | 01:41 PM
A. B. Hair's Avatar
Oil change, removal of bottom engine cover
thanks, I'll have it to do next week. Still seems it could be designed a little easier.
Marlin84
Apr 1, 2020 12:52 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
c_elliott83
Sep 25, 2015 07:55 AM
DRG35R
Sep 16, 2015 05:33 AM
