Coolant change?
Old Aug 13, 2011 | 10:07 PM
  #31
IEMaestro's Avatar
No problem man! Looking forward to the pics!
Old Aug 14, 2011 | 04:30 PM
  #32
kool_yaar's Avatar
Still raining so ill post real pics when i can but till then these pics from FSM should help you understand where all the three screws/valves are...
The first is of the drain plug, second is of the radiator relief plug and the last of the core relief plug. drain and radiator plugs are easy to find and access, the core plug is just a little hard to get to using a hex key if you dont want to take the engine cover off, but with a hex screwdriver it should be very easy.
Old Aug 14, 2011 | 05:15 PM
  #33
IEMaestro's Avatar
This will help a lot! Where can I get a copy of the FSM?
Old Aug 14, 2011 | 06:09 PM
  #34
vqsmile's Avatar
Infinitihelp.com
You can download it for free after you register on their website.
Old Aug 18, 2011 | 12:13 AM
  #35
IEMaestro's Avatar
Finally did this yesterday...it was a piece of cake! Thanks guys for all of the useful info. on how to do this!
Old Aug 18, 2011 | 05:26 AM
  #36
kool_yaar's Avatar
^ nice job, isnt it nice to see that coolant reservoir actually holding clean coolant for a change!
Anyways keep any eye on the temp gauge and check coolant levels over the next few days, mine went to the middle level after some hard driving on day one that i topped off and has been fine since.
Old Aug 18, 2011 | 09:32 PM
  #37
IEMaestro's Avatar
Yup...my old coolant was disgustingly dirty!! Ive been checking the coolant level every day since, and have had to add a small amount the past couple of days.
Old Oct 16, 2011 | 12:20 AM
  #38
Triton3.5's Avatar
So its not really neccesary to find, or open motorblock drain plugs on these cars?? also did you guys sort of idle the car, With the heater valve open, so as to get all the heater core coolant out as well.... or does it drain out normally with this proceadur and it seems the car should be fairly level right??? thanks guys!! for any answers to these....
Old Dec 10, 2011 | 02:55 PM
  #39
Dragonslayer's Avatar
Im not much of a mechanic but my car has 54k mileage. Should I look into changing the coolant. Infiniti said that it is due for a change but that doesnt mean that they checked the fluid and its dirty. Or is it ok for me to just wait to 60k?
Old Dec 10, 2011 | 05:06 PM
  #40
vqsmile's Avatar
Original factory fill is supposed to be good for 60K miles.
Old Feb 12, 2018 | 07:05 PM
  #41
Samuel Kwok's Avatar
What o-rings do I need? Can someone please post a link or part list?
Old Feb 12, 2018 | 07:16 PM
  #42
Scorpi0's Avatar
O-rings for what?
U shouldnt have to change any O-rings for a coolant change.
Old Feb 12, 2018 | 07:21 PM
  #43
Originally Posted by Scorpi0
O-rings for what?
Okay then I don't get them. I just read it was a good idea to do so.
Old Feb 12, 2018 | 07:22 PM
  #44
FreshLikeAG's Avatar
There's an o-ring on the drain screw the service manual recommends replacing each time.
Old Feb 12, 2018 | 07:35 PM
  #45
Scorpi0's Avatar
Its most likely still good tho....no?
