Need to Reset ECU, disconnecting battery but car still retains data
Old Sep 3, 2015 | 01:51 AM
esotericrider's Avatar
So I cleaned my ECU and now my car is revving by itself from 1500 to 2000 RPM. I want to reset my ECU, I disconnected the negative terminal and left it off for 18 hours. The trip mileage resets and all that but my radio station presets are still there which makes me believe my car is still retaining information. How is this possible? Should I pull the DSM fuse or disconnect the negative and positive leads?
Old Sep 3, 2015 | 07:57 AM
Urbanengineer's Avatar
Just pull the negative cable, turn on the headlights (insta depletion of stored energy) and turn back off the lights. Put the negative cable back on... Wala.
Old Sep 3, 2015 | 03:41 PM
LoSt180's Avatar
If you have a bluetooth OBD2 dongle, you can just use Nissan DataScan II (NDSII) to clear faults, then go into work support and clear self learn, those two basically reset the ECU. If you disconnected the throttle body, or cleaned it, then you can use that app to perform Idle Air Volume Learn at the press of a button (no fancy pedal dance needed).
Old Sep 3, 2015 | 07:21 PM
vqsmile's Avatar
Just because your radio retained its presets doesn't mean your ECU wasn't reset. The radio may just write them into some non-volatile memory in the head unit. If you pulled the neg terminal and left it for 18 hours, then you reset your ECU, and any volatile memory was erased. If you're still unsure, then just do the pedal dance and force an ECU reset that way.
BTW, have you found any other Nissan dealers yet?
Old Sep 10, 2015 | 08:18 PM
Did not work
Old Sep 10, 2015 | 08:19 PM
Not yet, do not want to pay those prices yet. Will call around tomorrow
Old Mar 4, 2019 | 07:43 PM
Roger44's Avatar
g35xS sedan all options
Is battery + and - connected when doing the ecu reset
Old Mar 4, 2019 | 07:53 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Post is 3.5 years old, probably doesn't matter at this point, any fuel trim problems he had have likely recalibrated by now.
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
mike730
Jan 12, 2018 04:25 PM
stay_tuned
Jul 21, 2015 07:09 PM
kenthung
Jul 21, 2015 05:56 AM
