Help with gas cap door and lock replacement and testing
Old Feb 13, 2018 | 05:42 PM
Samuel Kwok's Avatar
Originally Posted by Scorpi0
Haha. Thatll work. Wrap it with some tape to make it thicker and put some shrink tubing over it if u wanna make it look less ghetto. Careful tho....dont use a lighter to heat the shrink tubing either lol.
OP...any progress?
I will have to work on it next weekend.
Old Dec 1, 2020 | 02:25 PM
C_infty's Avatar
G35C M/T
I just repaired mine in a similar way, though mine had a broken chunk sticking out.
I used 7/32" ID aluminum tubing which fit snugly around the remaining bit of the tab, wrapped it in electrical tape so it fit snugly but not tight in the hole, then put epoxy in the tube and glued it on, and epoxied the electrical tape at the other end so it doesn't delaminate.
EDIT: I spoke prematurely, it already broke! The broken part was too difficult to get at to clean, I'm guessing the dirt caused poor adhesion.
Old Dec 5, 2020 | 07:24 AM
Scorpi0's Avatar
Put some gorilla glue on the tip of a screw and screw it in there. Should hold.
Old Dec 5, 2020 | 09:03 PM
C_infty's Avatar
G35C M/T
There's no hole to screw into though, it's a jagged piece sticking out of the original latch, hence the tube. I just couldn't get the JB Weld to stick since I couldn't clean the surface.
Old Dec 6, 2020 | 11:40 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It's pretty easy to remove the entire lock assembly, take off the side liner in the trunk and it's right there. Once it's out of the car you should be able to fix it.
Old Dec 6, 2020 | 07:25 PM
C_infty's Avatar
G35C M/T
Ah, I didn't realize there was no bolt securing it! Just had to yank it out through the weird shaped hole with the black plastic clip off.
Unfortunately, I can't figure out how to get the unit open to replace the latch (I don't feel like trying to glue stuff to it again). I will try to find a whole working unit off a parts car one of these days.
Old Jan 7, 2021 | 12:02 AM
Crawford842's Avatar
G35 Sedan
I’d recommend going this route.
chadster2049
May 3, 2013 09:14 PM
saltyload
Aug 11, 2012 05:22 PM
Trickstyle
Interior
Dec 27, 2011 06:51 PM
TheSpoonyBard
Aug 21, 2008 01:54 AM
