Removing radiator fan unit
Old Jun 16, 2019 | 09:56 PM
Cabrito's Avatar
07 G35S 6MT
EDIT: I think I figured this out...
EDIT: No I didn't
Ok - I need to remove the radiator fans. But there's a wiring harness attached to it with a
few clips. Is there an easy way to get that harness off without destroying the clips?
Thanks in advance.
Old Jun 17, 2019 | 02:46 PM
Urbanengineer's Avatar
Not really sadly, those clips are meant to never come off. Good lucks
Old Jun 17, 2019 | 03:06 PM
Cabrito's Avatar
07 G35S 6MT
I think I just need a pair of these
Looks like you can unclip them from the back if you can access. This might
do the trick.
I was able to do the repair without fully removing the fans, so I'm ok for now.
Thanks
Old Jun 17, 2019 | 03:24 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Just cut them and replace them with new ones, or use cable ties to support the harness as needed.
Kennycaine
Jun 16, 2018 12:17 PM
Tollboothwilley
Dec 29, 2009 01:48 AM
GT-ER
11
May 26, 2009 02:38 PM
infinitialex
Jun 15, 2007 02:07 PM
jakeup93
Jun 18, 2005 03:20 PM
