Timing replacement parts
Old Sep 8, 2023 | 10:15 AM
Jmello36's Avatar
G35X
I have a 2008 G35x sedan and I'm looking to replace the timing chain, gears, tensioners and guides. My water pump went out and I figure while I'm that far in It's a good time to do everything. I've looked up kits , but most just list G35. Are the VQ35DE and the VQ35 HR parts interchangeable? I'm also looking to change the gallery gaskets (if needed) as well. Any help would be much appreciated. Thanks, John
Old Sep 8, 2023 | 09:50 PM
Urbanengineer's Avatar
I would recommend just buying a Chinese HR kit. You have the 3.7 HR, right?
Old Sep 9, 2023 | 11:10 AM
Jmello36's Avatar
G35X
No its an 08 G-35. In 07 the sedan had the new 3.5l VQHR engine and the coupe still had the older DE engine. In 08 the both had the HR and my car is 08sedan. My question is they mostly say G35 or G35DE. Are they the same parts for both engines? I'm not sure? Thanks for trying to help me, I do appreciate you.
Old Sep 11, 2023 | 10:49 AM
The HR doesn’t have the same timing setup as the 3.5L VQ’s.
seems the timing components are similar for most cars with the 3.7L VQ. Example: 370Z, M37, G37, etc.
VQ37VHR timing kit found quite a few results
Chopper
Feb 3, 2026 08:04 AM
Jmello36
V36 Engine, Exhaust, Drivetrain & FI
Sep 7, 2023 07:15 PM
Jbl_91762
Jan 23, 2017 09:11 PM
Hiro
Mar 27, 2013 06:43 PM
gdriver2010
Apr 10, 2012 05:14 AM
