V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Need help installing fog light
Old Jul 14, 2008 | 10:47 PM
  #46
stixman6's Avatar
Any of you guys that installed the Luminics JDM yellow fogs have pics to post?
Old Jul 30, 2008 | 10:38 PM
  #47
DKS08G35's Avatar
just a quick question, since u can change the fog lights by taking out the airboxes, since u have access to the headlight assembly can u also have access to the headlight bulbs. I have seen numerous post of people upgrading the oem H.I.D bulbs to 6000k and so on, but they all said that they had to take the front wheels off and take the lining of the wheel well plastic off and doing it that way, it just seems easier to just take out the airboxes. let me know if doing it that way you can access the headlight bulbs.
Old Jul 31, 2008 | 01:20 AM
  #48
kool_yaar's Avatar
From my experience you have to go through the wheel well as form the top you cant get to the headlamps as its more to the right of the fogs ...
Old Aug 3, 2009 | 03:11 PM
  #49
kanji0513's Avatar
guys, after I took out the bolt that lock the intake box, do I have to loosen the whole intake pipe to remove box? or I could just lift box up?
Old Jan 13, 2010 | 12:15 PM
  #50
pattyballs's Avatar
Does anybody know what bulbs we need for an 07 sedan? im looking to get the Lumanics krypton yellow JDM is it the 9006 bulb? Please pm
Old Jan 15, 2010 | 05:10 PM
  #51
kmuniz78's Avatar
Yes! There should be sticky's for all this info!
Old Apr 11, 2011 | 10:29 PM
  #52
G-MAN (CANADA)'s Avatar
Pics with yellow fogs would be GREAT!!!!!!!!!!!! its only been mentioned here 3 + times
Old Jan 10, 2012 | 03:17 AM
  #53
D/\Rk Stoc|{er's Avatar
Got to the fog light bulb, turned it counterclockwise, but the sucker wont pull out?!?! I'm pretty frustrated right now!!
Help please!!
Old Jan 10, 2012 | 02:38 PM
  #54
Nm...finally got it last night. You just have to wiggle it as you're pulling the bulb harness out. I kept turning the harness clockwise and counterclockwise (back and forth) until it eventually "loosened."
And yes, the passenger side was harder to take out because of the limited space. Had to pretty much install with one hand.
chinee
Jun 10, 2024 07:48 PM
Jusseth
Sep 13, 2020 12:25 PM
Freddy07g35
Sep 17, 2015 08:53 PM
Fireman07603
Aug 9, 2015 06:00 PM
attarday
Jul 15, 2015 04:03 PM
