V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
quick LED question
Old Apr 7, 2008 | 08:47 AM
claytong35's Avatar
quick LED question
Sorry if this is posted somewhere else but I couldn't locate it through searches. I just replaced my licence plate lights with some vleds and loved the look so now I'd like to do the door entry lights. Can someone tell me what size lights go in the door for a 2007 G sedan? Any help would be appreciated.
Old Apr 7, 2008 | 06:24 PM
Rizzagt22's Avatar
T15 LED's for the entry door lights.
Old Apr 7, 2008 | 08:08 PM
kool_yaar's Avatar
194 led bulb superbrightleds
Old Apr 7, 2008 | 09:36 PM
stanfna's Avatar
same bulb as the tag lights. in fact...all the interior lights are the same bulb.
Old Apr 7, 2008 | 09:39 PM
carz's Avatar
are the bulbs plug-n-play? i am planning on doing the same mod
how many bulbs do i need to do the whole interior? Will fade in/out be effected?
Old Apr 7, 2008 | 09:48 PM
claytong35's Avatar
Good to know!! So glove box is 194 as well? Will 6 LED be bright enough or should I go up to 9 or 12? Also is there any place on the cover that is best to pop it off so not to break anything? I looked and it is not clamped like the tag and didnt see a particular place to remove it. Thanks for the help
Old Apr 7, 2008 | 09:49 PM
stanfna's Avatar
checkout this thread...
https://g35driver.com/forums/v36-general-tech-questions/188929-bulb-size-2007-g35.html
there are links to other good threads in post #12
Old Apr 8, 2008 | 03:16 AM
ofna's Avatar
i replaced all my interior lights with led's....i've noticed that when i have the switch on door that the led's are still lit even with the doors closed, but when you put the switch to off it's completely turned off....
skippyG
Jan 25, 2016 01:18 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
