V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Tighten the HOOD
Old Oct 20, 2008 | 10:34 PM
earth0's Avatar
Tighten the HOOD
Hey! does anyone know how to tighten the hood.Mine was moving abit when i press it down.
Old Oct 21, 2008 | 10:07 AM
IvoryPearl07G's Avatar
yea, there are two rubber stops on the front corners of the hood. they basically screw in to the hood. turn them counter clockwise to get more height out of them. do a couple of turns at a time on the loose side of the hood, then close to check clearance. you should be able to tighten the hood up after a few tries.
Old Oct 21, 2008 | 12:45 PM
earth0's Avatar
Hey! Thanks! I will try it now.let see if it work.
Picture Share
Feb 4, 2018 12:41 PM
hrdwirk1
Oct 2, 2015 06:34 PM
