V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Question regarding Rear View Mirror
Old Oct 29, 2008 | 01:25 PM
Jackooze's Avatar
Cool Question regarding Rear View Mirror
Hey guys, I wanted to know if there is any way to disable the rear view mirror sensor that dims darker when headlights shin into the car. The reason why I am asking is that I have 20% tints on my rear where at night I cannot see well into the rear view mirror.
Thank You.
Old Oct 29, 2008 | 01:36 PM
soundmike's Avatar
Thank You.
There's a switch right on the mirror itself to turn it off.
Old Oct 29, 2008 | 01:37 PM
Jackooze's Avatar
Thanks for the reply. I knew that but is there any way to make it permanent ?
Old Oct 29, 2008 | 07:01 PM
CyberSky's Avatar
No. At least there's nothing in the manual about that. Maybe you can cut a small, square piece of opaque tape and put it over the sensor? If it's dark outside but the senser doesn't have any light shining on it, then I guess it won't dim what you see in the mirror?
Old Oct 29, 2008 | 07:24 PM
kid4now's Avatar
You could put lighter tint on your rear window then you wont have that problem.
Old Oct 29, 2008 | 08:54 PM
Csquared's Avatar
You could rip off the mirror and put a conventional one on, plus then you'll never run the risk of the rattle sound from there.
Old Oct 30, 2008 | 01:25 AM
Ground Beef's Avatar
I think that if you cut the brown wire to the harness that connects into the mirror it will disable it, but it's just a suggestion. I don't want to be responsible if you F anything up.
mjfenix
Aug 17, 2017 05:49 AM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
