Hi! Fella G,
Someone help me!! Mine LED Tail Light and License Plate are OUT!!!
after i try to replace the bulb on license plate.Suddenly a static came up once and all tail light and license light is gone.Led Brake Light is working only when you push the Brake.I check all the fuse and none of them is broken.
Pls.!! Help. I hope i'm not burn out the LED. I got this car on Mar 08.
Not sure if waranty cover?
Hmm, I'm sure if you took it to the dealership and not tell them you were messing around with the lightbulbs they'll fix it under warranty.
Lol, it’s a fuse. I JUST replaced all the lights in my car with LEDS. When I was doing one of the map lights I caused a static short and blew a fuse. I had NO interior lights. I checked everything and swore all fuses were fine. I then rechecked cause its dark outside and found a 10amp Fuse to be broken (its very hard to see that its broken though). Upon replacing the 10amp fuse, all my interior lights now work.
I can’t find these type of fuses at Homedepot, PepBoys, or Advance Auto Parts. Where do you guys get your fuses? I would like to buy another 10amp fuse to keep in the spare 10amp fuse slot.
Finally after all search.Da'm Nissan PITA 3rd Fuse Box locate on the left side of the Battery. There is a big black box and nothing explain on the boxes
i will post up picture later today.End up is i fried one fuse.Yeh!!!!!
I have post on other thread.Mine Bad.
I've took some picture during taking out the 3rd Fuse Box.I think this will be great info for someone (like me) who don't know.GL
https://g35driver.com/forums/g35-cou...ml#post3660021
Clean that engine bay.... you should be ashamed of yourself. Originally Posted by earth0
I have post on other thread.Mine Bad.I've took some picture during taking out the 3rd Fuse Box.I think this will be great info for someone (like me) who don't know.GL
Quote:
Dude! I always did mann. you will be asham too if you open the wholecover from battery to half of the windshield.Mine engine bay is always clean BTWOriginally Posted by AesonVirus
