V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Cabin Air Filter Replacement
Old Jul 22, 2009 | 02:55 AM
tg1234's Avatar
Originally Posted by rpm&my_G35
Wow!
I just looked at your link. The EXACT same filter is sold here for $44.99+tax. What a rip off. We get so screwed up here.
You can buy the Fram filter from Ebay for 17. That's what I did. I also bought the Airfilters for engines HKS so I don't have to buy it from Infiniti. Do your own shopping and maint. and save.
Old Jan 28, 2010 | 07:11 PM
isbn1975's Avatar
Could anybody tell me if I installed the filter correctly?
It says on the sidewall "Air Flow" with the arrow pointing downward. I'm not too sure if it means air flows "in" or "out." May be I should ask the MFG?
It is a FRAM air filter.
Linky Linky
Installation wasn't too bad. It took me about 20 minutes. Probably won't take anymore than 10 minutes next time. Can't believe dealer charges almost $100 for this.
Old Jan 28, 2010 | 09:14 PM
greg_atlanta's Avatar
2008 G35 Journey Sedan no sunroof
Looks right to me. Is that the exact same size as the OEM filter?
Old Jan 29, 2010 | 12:42 AM
isbn1975's Avatar
Yes, it is. First, I was skeptical too as it had too much gaps but it's the same size. Weird, huh?
Old Jan 31, 2010 | 01:05 PM
blnewt's Avatar
It is a FRAM air filter. Linky
Air should flow into the firewall, so arrow should point up, that's the same filter I used too. Only problem I had was trying to get that screw that's way in th eback of the glove box, it tightened up but probably cross threaded
blnewt's Avatar
Air should flow into the firewall, so arrow should point up, that's the same filter I used too. Only problem I had was trying to get that screw that's way in the back of the glove box, it tightened up but probably cross threaded
Old Jan 31, 2010 | 09:18 PM
JMZ_blkobsidian's Avatar
Pep boys = $11.00, DIY = 10 minutes
Pep boys carries the in-cabin microfilter for 07-08 G sedans. $11.
Old Feb 1, 2010 | 08:25 PM
Domesticdemon's Avatar
Thanks I'll pick these up on the way home from work
Old Feb 2, 2010 | 09:35 AM
Iamtodd's Avatar
Went to autozone and got a replacement filter last night for $18. Not sure why i decided to do it outside, in the dark in 20 degree weather..but anyhow took me a while to get the glove box out...the damper pin was hard for me to get out...but once i got that off everything else went smoothly. Thanks for posting this up. My old filter was quite dirty...33k miles.
Old Feb 5, 2010 | 05:39 PM
suby01's Avatar
http://www.autozone.com/autozone/cat...&parentId=42-0
is that a good filter to go with?
Old Feb 5, 2010 | 05:52 PM
snowcrossmxz's Avatar
You can get a carbon/charcoal one for the same price on amazon or eBay
Old Aug 17, 2010 | 07:07 PM
becundo's Avatar
I bought my Charcoal Filter from ebay only cost me $11 shipped to my door. It is a 100% better in terms of material quality than the OEM one that was installed on my G35 (****ty paper one). I don't think the first owner ever replaced this filter so I took a picture this way you guys can see how nasty yours could probably be if you have never changed yours.
forgot to add that this came from a G35 2004
derres
Aug 28, 2015 03:27 PM
CJay
Aug 1, 2015 03:57 AM
vstypicals
Jul 20, 2015 10:55 PM
justgotg35
Jul 19, 2015 12:33 PM
