V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Nismo front lip install help
Old Mar 24, 2010 | 09:57 AM
suby01's Avatar
just looking for options on how you guys put yours on?
would self tapping screw work, do i need washers or whatever?
i also heard from some people that to drill a hole and use a nut and bolt to hold it on.
whats the best choice for me? with any pictures of the bolts/screws so i can go to the store today and try it out. THANKS
Old Mar 24, 2010 | 11:19 AM
AesonVirus's Avatar
Did the lip come with hardware, templates and instructions? I'm not sure why you are asking for details on what types of bolts/screws to use.
The lip should come with some cut out templates. They are pretty detailed and show you where they need to be cut and folded. They are then taped into place on the car and these templates show you where to drill holes, and what size they should be. There are small holes and then larger ones placed beside them (about an inch in diam)
The large holes accept a metal clip that covers the smaller hole beside it. This metal clip accepts the screw that holds the lip into place.
The lip is held in place with both tape and screws. The screws into plastic alone would not hold very well so that's where the metal clips come into play.
Biggest PITA is getting the holes drilled. I lifted the front end up so I could get the drill underneath. Other than that, it was a pretty smooth install. Took me a few hours, taking my time to get it right the first time around.
Old Mar 24, 2010 | 11:37 AM
suby01's Avatar
nope no hardware included. aaaah so thats why im missing something.
Old Mar 24, 2010 | 02:02 PM
kool_yaar's Avatar
^ you are missing a lot like Aeson said(beat me to it ) did you buy this new or used? cause having the template and hardware will help a lot and make life easier with a 15-30min install.
Old Mar 24, 2010 | 02:07 PM
mj_39's Avatar
if you bought it new check the bottom of the box hardware was taped at the very bottom when i got my lip
Old Mar 24, 2010 | 02:23 PM
AesonVirus's Avatar
And I just threw my templates out a few months ago. They've been sitting in the garage for a year and I knew I'd never need them again.
Old Mar 24, 2010 | 02:32 PM
suby01's Avatar
i got it from riverside. !@#$% maybe it is in the box somewhere. i was surprised that there was nothing included. i will quadruple check when i get home.
keep you posted.
Old Mar 24, 2010 | 02:47 PM
kool_yaar's Avatar
FYI if you dont find it taped in the box just contact riverside and they will own up and send you a replacement they are great to deal with.
Old Mar 24, 2010 | 02:59 PM
AesonVirus's Avatar
I got mine from there as well.... double check.
Old Mar 24, 2010 | 03:14 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
keep you posted.
It's in plastic & usually taped to the inside of the box
Old Mar 24, 2010 | 03:28 PM
LightsOut's Avatar
SIETESG
for it being taped to the box
Old Mar 24, 2010 | 04:25 PM
suby01's Avatar
kk. thanks everyone. super anxious to get this checked. updates asap when i get home.
Old Mar 24, 2010 | 05:59 PM
AesonVirus's Avatar
Prepare to be called a meathead if they're in the box
Old Mar 24, 2010 | 06:41 PM
suby01's Avatar
me
false alarm.
for everyone who helped me.
just a meathead?? i can take that, i would expect something far worse.
i was just testing you guys if you remembered where your parts were located.
Old Mar 24, 2010 | 06:46 PM
AesonVirus's Avatar
LOL... Meathead!
Glad it's all there... now instal it and post em' when you got em'!
