V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
projector shroud
Old Jan 12, 2011 | 11:56 PM
zoop425's Avatar
projector shroud
Does anyone know where I can get a set of the projector housings (the whole assembly with lenses) from 07-08 headlights? When I open my headlights in the spring to paint them, I am going to do a quad projector retro.. I am going to remove the parking light housing and shave. And then, cut the divider between the blinker and fog, and install a second projector in the middle that acts as fog lights and a blinker. Let me know what you think and where I can get these things at!
Old Jan 12, 2011 | 11:59 PM
CandlestickPark's Avatar
ill Sedan
Your best bet is to buy a set of headlights from eBay. I have a friend retrofitting 2nd gen sedan projectors into his 03 Sedan headlights and that is where is got his from.
Old Jan 13, 2011 | 12:05 AM
zoop425's Avatar
I was looking at that but each one costs like 400 bucks.. 700-800 bucks is really pricy for what I want to do.. is there a generic housing that is good quality that I could use? Also does anyone know if the car cares if it does not have parking lights or do I need to order some load resistors?
Old Jan 13, 2011 | 12:07 AM
ill Sedan
If you aren't set on 2nd gen sedan projectors check out retrofitsource.com, lots of good stuff there.
By the way if you search around on eBay long enough you'll find a much better deal than 700-800 bucks.
Old Jan 13, 2011 | 01:30 AM
ChinkyChoy's Avatar
ebay would probably be your best bet if not then at the junk yard to find parts
Old Jan 13, 2011 | 02:10 PM
zoop425's Avatar
I think this is what im going with..
http://www.theretrofitsource.com/pro...roducts_id=236
for the projectors (does it matter that they are are hi/low? how can I keep them in the low posistion for my fogs?)
http://www.theretrofitsource.com/pro...products_id=72
for the shrouds
http://www.theretrofitsource.com/pro...roducts_id=134
clear lenses for OEM projectors
http://www.theretrofitsource.com/pro...roducts_id=103 (x2)
I will put these inside the projector housings to shine through the vents (They will work as the parking lights) as I will be taking out the stock parking light housings.
I think thats a pretty reasonable price overall! $275 for the whole project. Now does anyone have any suggestions about the blinker? I currently have white led blinkers but I want to go back to amber to be more legal. Where should I put them or intigrate them so they are stealth? thanks!
Old Jan 13, 2011 | 06:26 PM
zoop425's Avatar
As I am looking into this more, is there enough depth behind the blinker/fog area for the projector?
Old Jan 17, 2011 | 12:08 AM
RhiNoKiLL's Avatar
Hey, I'm selling my headlight it has everything in it. check it out here and shoot me an offer. I want it gone so I'm flexible with price.
http://myg37.com/forums/private-clas...headlight.html
Old Jan 17, 2011 | 04:03 PM
zoop425's Avatar
lol do those look anything like what im talking about here?
Old Jan 18, 2011 | 11:00 PM
RhiNoKiLL's Avatar
it says 2007-2008 projector lenses from the headlights... since this is 2nd gen sedan... i dont see how that is NOT what you want...
Old Jan 19, 2011 | 12:15 AM
zoop425's Avatar
I ended up going a different route unless you can sell just the shroud?
Picture Share
Feb 4, 2018 12:41 PM
lil beezy
Lights
Nov 16, 2015 02:52 AM
MrIP35
Oct 25, 2015 11:13 PM
alessandro
Oct 8, 2015 09:29 AM
