V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Issue with aiming headlights
Old Mar 22, 2011 | 07:29 PM
Viet2100's Avatar
Hi guys. I did a search and did not find a definite answer.
I recently dropped my V36 sedan and the headlights are now basically pointing at the ground in front of me. I went ahead, pulled up on a wall on a level surface and adjust them up to about normal height. I understand that my headlights have auto levelers. So they basically just reset it back to pointing at the ground.
So I guess my question is does anyone know where the auto leveling balancer is on our vehicles? I was thinking it might be tied into the ICC front sensor. I have adjusted that a few time up and down, but no luck. And I am not sure if this is why I have not been able to use my CC due to the "slip, VDC OFF, ABS, and BRAKE" lights on the dash being lit. Thanks in advance.
Old Mar 22, 2011 | 07:55 PM
kool_yaar's Avatar
those (brake vdc etc) lights are probably on cause you are low on brake fluid(main reason being low on pad), search and there is a post by soundmike where he has a pic of the headlight adjustment screw.
Old Mar 22, 2011 | 07:56 PM
kool_yaar's Avatar
Here ya go.... u can thank soundmike for this.
Old Mar 22, 2011 | 08:48 PM
Viet2100's Avatar
I topped off the brake fluid. You think I may just need brakes? To be honest, I haven't even checked myself =/
And I know where the headlight vertical adjustment is, it's just that I have AFS and auto-leveling so the car keeps pointing them back down.
Old Mar 26, 2011 | 10:33 PM
soundmike's Avatar
^ that doesn't sound right. I have AFS and i was able to adjust the lights just fine. I believe all that AFS really does is limit the movement within the range that the light output is physically adjusted to.
Granted, i have no way to confirm that except for the fact that my lights are just no longer pointing merely a few feet away from the bumper.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
bTanz
Oct 15, 2015 02:31 PM
derres
Aug 28, 2015 03:27 PM
Karnicle
Jul 23, 2015 05:08 AM
