V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Added fog lights to my bumper
Old Jun 26, 2011 | 02:08 PM
  #46
zoop425's Avatar
yeah thats normal .. HIDS throw off a ton of heat that's why the back of the blazers are metal and not plastic. BTW how did you mount your fogs. Same way I did?
Old Jun 26, 2011 | 02:15 PM
  #47
salvador312's Avatar
Yeah!! Sports bumper direct bolt on! I am not in hurry so maybe until next year! But you never know! That's what I said about my Akebonos! And I got them a year sooner! I am evil!! I would love doing the 2010 convertion but that's over $2000!! I always love real fog lights!!
Old Jun 27, 2011 | 03:30 PM
  #48
samsizzle's Avatar
dude idunno how you attached it to the car then managed to drill the holes on the bumper to match them, such a pain in the *ss to keep comparing them to get them perfect lol I just measured and drilled the holes then attached them to the bumper with some brackets and screws that are covered by the gasket hence the weird angling. Im gonna re-aim them later and fix the angling somehow.
question- how high are yours aimed? I dont know whats supposed to be normal when they are pointed at a wall. Should they be like a foot lower than the beam pattern the headlights make or more or less?
Old Jun 27, 2011 | 03:54 PM
  #49
zoop425's Avatar
If I were you I would not attach them to the bumper.. I was thinking thats what it looked like you did but wasnt sure. I didnt drill the bumper after mounting them. I marked where the holes should go based on obstructions behind the bumper, drilled them, then had a friend tell me when the fogs were lined up in the holes when I was holding them from under the car with the bumper on. I then marked the holes in the brackets that made them line up, drilled and bolted on. I aimed mine to be even with my headlights (my windshield is tinted and I wanted extra light output). If you attach them to the bumper like you did you will not be able to aim them up and down and they will look weird because they will point out. When mounting them like I did you can mount them parallel and recess them so they are not aiming out. Also if you have them attached to the bumper they will shake and move when you hit a pothole.
Old Jun 28, 2011 | 02:52 PM
  #50
GXXXV X's Avatar
does anybody know if i could just splice the stock wires going to my fogs? instead of buying a whole new harness? also would i even be able to use the harness in the link provided since im not going with HIDs?
thanks
Old Jun 28, 2011 | 03:08 PM
  #51
zoop425's Avatar
If your not using hids you dont need the harness. Thats just for the huge amount of power hids take to power up. Just splice and go for you my friend!
Old Jul 4, 2011 | 02:35 AM
  #52
GXXXV X's Avatar
finally got the fogs installed but now i realize i shoudve gotten the HID stuff for full color! lol can someone please advise which relay to get?
also, are ballasts interchangeable or do i need to get TRS ones for the blazers?
Old Jul 4, 2011 | 02:37 AM
  #53
Post pictures!!! ASAP!
Old Jul 4, 2011 | 02:39 AM
  #54
GXXXV X's Avatar
lmao bumperless drift style
Old Jul 4, 2011 | 02:52 AM
  #55
That looks pretty cool!!! Where exactly did you get the fogs! Link please!
Old Jul 4, 2011 | 02:53 AM
  #56
GXXXV X's Avatar
lol thanks! just used the links form the first page, but i definitely should have gotten HIDs to put in the fogs instead cause i want true 3000k color lol
http://www.theretrofitsource.com/pro...hrhmi53e644vuj
Old Jul 4, 2011 | 03:05 AM
  #57
Where do you get the HId for these?! And do they come with the brackets shown on the last picture?!
Old Jul 4, 2011 | 03:11 AM
  #58
GXXXV X's Avatar
you can get all the hid stuff on their site, you can opt to get the HID bulbs with it when you order as well (the halogens come with it for free), but the ballasts are kinda expensive:
35w ballast: http://www.theretrofitsource.com/pro...hrhmi53e644vuj
and apparently for the HID we need a relay harness but i dont know which one to get?
EDIT: no i got the brackets at home depot as well as some [unnecessarily long] carriage bolts that go through the WHOLE bumper lol you can see it in the pics^^ the bolts are 1/4 x 6"
Old Jul 4, 2011 | 03:16 AM
  #59
Damn!! Way to expensive!! Maybe buy some cheap ones on EBay! And make them fit!
Old Jul 4, 2011 | 03:17 AM
  #60
GXXXV X's Avatar
lol that sounds like a good idea! do you know if theyre interchangeable?
btw LMAO at the $11 ballast on ebay ftw it says it fits all sizes!
