Added fog lights to my bumper
#96
For those who have done the hid wiring, can someone please explain to me where all the plugs go? I know its a noob question but I don't get it at all. Like there is a round plug coming off the ballast and I can't figure out what it is for...
Also on the wiring harness there is a plug for low beam and one for high beam... which one should I use for the fogs?
Also, do I only need one wiring harness or two? I can't figure out how to get power to the other side light without buying another harness...
Sorry for all the dumb questions but im really confused about this ...![Frown](https://g35driver.com/forums/images/smilies/frown.gif)
![](http://i1091.photobucket.com/albums/i386/Warwick_Solow/2011-08-18_00-02-36_63.jpg)
![](http://i1091.photobucket.com/albums/i386/Warwick_Solow/2011-08-18_00-03-45_113.jpg)
#97
you got balasts for d2s bulbs? why? those will not work with the bulbs you have there without a converter cable .. but regardless, once you have that figured out.. The harness goes the the battery and gets grounded.. it has a lead that goes to the turn on signal (the stock fog harness) and this may have a plug or may not (then it has to be tapped in) depending on if you got a universal one or one for 9006 specifically. then there are 2 other leads and each goes the the big port on the ballasts.. then you connect the 2 cables on each balast to the bulbs and presto!
GXXXV X (08-19-2011)
#100
