V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
HID Reverse Lights
Old 06-20-2011, 11:35 PM
zoop425's Avatar
20 minutes? You didnt have to connect it to the battery?
  #32
Old 06-20-2011, 11:36 PM
GEDsetG35's Avatar
i do it has all the info on the box ill look for it tomorrow, has a fuse attached to the cable
  #33
Old 06-20-2011, 11:43 PM
zoop425's Avatar
How did it take 20 min including running a cable to the battery?? Lol
  #34
Old 06-20-2011, 11:46 PM
GEDsetG35's Avatar
u dont have to run a cable. from the ballast to the bulb theres a fuse. ill take a pic of how everything is set up
  #35
Old 06-20-2011, 11:52 PM
zoop425's Avatar
It must be an extremely low wattage kit if it takes its power from the reverse light harness and not from the battery.. im doing 35 watts so it needs to go to the battery and have a turn on relay to the reverse lights
  #36
Old 06-21-2011, 02:59 AM
maclovio's Avatar
This will be my next mod. Looks siick! Plus i have double tint, so when i back up i can't see chit!
  #37
Old 06-21-2011, 04:10 AM
apexi957's Avatar
Subbed!
  #38
Old 06-21-2011, 04:55 AM
berniEE's Avatar
doesn't melt your housing..??
  #39
Old 06-21-2011, 11:55 AM
kool_yaar's Avatar
^ considering the amount of time the reverse lights are on for, i doubt it, however it is a possibility imo.
  #40
Old 06-21-2011, 12:16 PM
djfarhan's Avatar
i wnna do this mod now! ;-D
  #41
Old 06-21-2011, 12:28 PM
jwolfpk's Avatar
^+1 cant wait to see finished pics and the DIY
  #42
Old 06-21-2011, 12:53 PM
J2S2M's Avatar
This is a nuisance for others IMO. If would be pissed if I was driving and saw some fool back out w/ these bright as$ lights!
  #43
Old 06-21-2011, 01:04 PM
jwolfpk's Avatar
i think its a great idea so people actually realize your backing out of a spot.. and at night my reverse lights dont even shine bright enough to light up my driveway or for me to see through my tints
  #44
Old 06-21-2011, 02:39 PM
zoop425's Avatar
The only time I have seen anyone melt their housing by doing this was on the TSX forum and it was due to a faulty ballast. Now he has been running them for 4 years with no issue. I think its great, it lets people know.. IM BACKING THE **** UP!!!! and it will let me see through my tints and on my backup camera which works ok at night but could be better. I just picked up some slim ballasts and a harness so Im all set.. will be installing this setup tonight!! I will include a DIY
  #45
Old 06-22-2011, 05:04 AM
harp00n's Avatar
A year ago I did it and used standart 35W HID, but powered it with the cord coming from battery to my aftermarket amplifier in the trunk:
https://g35driver.com/forums/v36-int...up-lights.html
p.s. btw, now it has no signs of melting or peeling inside of the backlights (using 35W H3 lamps)!
Quick Reply: HID Reverse Lights
