V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
2007 G35S Sedan Headlight Issue
Old Dec 18, 2020 | 04:52 PM
Joenavy85's Avatar
G35x Base
Double tap
Old Mar 26, 2021 | 01:56 PM
bgaz423's Avatar
Stock
I am also having passenger side headlight issues, replaced bulb, this didnt fix it, replaced ballast, no luck either, but when i did replace ballast i used the pre-exhisting power cable (as it is a pain in the *** to get out the actual head light) and just plugged the old one into the new ballast with new bulb. Any ideas? wondering if its a ground issue or if I should suck it up and exchange power supply cable as well?
Old Mar 26, 2021 | 02:32 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Rather than throwing parts at the car hoping something will fix it I strongly recommend just swapping components one-at-a-time from one headlight to the other until you isolate what the bad part is.
You can also test the harness for correct voltage/ground using a digital multimeter. Steps are in the FSM section EXL - Exterior Lighting, wiring schematic is around page 88.
https://www.nicoclub.com/infiniti-service-manuals
tnobull
Aug 14, 2018 11:28 AM
Choza0907
Oct 22, 2013 02:40 PM
g35westcoaster
May 29, 2013 09:46 PM
spen.brock
Lighting
Apr 11, 2013 03:36 AM
Rphillips6487
Lighting
19
Jul 6, 2007 03:29 PM
