Kics Project Spacers in Stock!!!!
Old Nov 6, 2007 | 05:53 PM
Mike@CZP's Avatar
Hey guys here are the Kics spacers I currently have available:
Project Kics Bolt-On M12x12.5 Wheel Spacers Pair 5x114.3, 11-30mm : $165.00 Shipped
PM me if you are interested. If you want to purchase online, please click on "Add to Cart" to be directly linked to our secure website.. Thanks!!
Aluminum Lightweight Wheel Spacers by Kics Project, Japan.
-Wheel Spacers are sold in a pair (2 spacers).
-Does not require changing of longer studs, these spacers come with studs on itself.
-Hub Centric Ring can be ordered seperately, it is recommended but not required.
You might also be interested in:
CZP G35 Short Lug Nut 12x1.25 17mm Hex : $2.50 Each
Old Nov 10, 2007 | 05:40 PM
Mike@CZP's Avatar
bump!
Old Nov 10, 2007 | 05:49 PM
HenryLee's Avatar
how much are the hubcentric rings?
Old Nov 12, 2007 | 01:15 AM
Mike@CZP's Avatar
hubcentric rings are $35 a pair. Thanks!!!
Old Nov 15, 2007 | 03:41 AM
GThIrtYFiZle's Avatar
Do you guys still have these for sale? And what do hubcentric rings do?
Do you guys still have these for sale? And what do hubcentric rings do? pm me thanx
Old Nov 16, 2007 | 07:03 PM
Mike@CZP's Avatar
I do not have the hubcentrics in stock at thte momnent, waiting for Mackin to send. Thanks!
Old Nov 16, 2007 | 07:23 PM
ttrank's Avatar
Grocery getter
Those are very nice.
Do you have any 3-5mm spacers in stock? I may need a pair next week and am local.
Old Nov 19, 2007 | 02:40 PM
Mike@CZP's Avatar
I have ichiba 5mm available!
Old Nov 19, 2007 | 03:53 PM
ttrank's Avatar
Grocery getter
In stock?
I'm testing my new brakes tonight so I may need to come down tomorrow for a set.
Old Nov 28, 2007 | 12:05 PM
Triple8Sol's Avatar
Are the 15mm spacers wide enough to clear the G35's stock studs? Since you leave the stock studs in the hub, I'm wondering if they'll stick out past the 15mm spacer?
Old Nov 28, 2007 | 12:52 PM
TimW's Avatar
I heard nissan studs were about 25-26mm off the rotor face, and that you'd need a 10-12+ mm spacing inside the wheel itself. I'm pretty sure our OEMs provide this.
Old Nov 29, 2007 | 04:39 PM
Triple8Sol's Avatar
I'm looking into these for aftermarket wheels. Volk fronts, to be specific.
Old Dec 5, 2007 | 05:06 PM
Mike@CZP's Avatar
bump! Hubcentric spacers are $28 per pair
Old Dec 6, 2007 | 12:42 PM
ttrank's Avatar
Grocery getter
Well I didn't end up needing spacers because the hats on these new brakes are thicker than the old ones I had. But I think I need a little longer studs. Can you buy just the studs that would come with say 5mm spacers?
Never mind. I just purchased some of the Nismo longer hub bolts.
