Tein and Hotchkis instock at JSC Speed
Old Apr 13, 2006 | 05:32 PM
JSCspeed's Avatar
TEIN Coilovers, Springs, and Hood Dampers In Stock at JSC Speed
TEIN SPRINGS
H-Tech Lowering Springs (mild Drop) and S-Tech Lowering Springs (big Drop)
Tein Flex Coilovers in Stock!!
Limited Time Offer
Products are shipped out the same day they are ordered, and tracking numbers are also emailed on the same day
Features:
*Full-length adjustment and height adjustment for separate setting of the height and spring preload.
*16 levels of damping force adjustment (compression and rebound together).
*Teflon coating for rust prevention.
*Newly designed spring seat and spring seat lock for easy height adjusting.
*Compatible with EDFC.
*Includes Rigid Front Upper Mounts and Rubber Rear Mounts
*Rebuildable
PM Me, Post your zip code, or Email me kyle@Jscspeed.com or call me at 215 364 5929 for Prices
Old Aug 8, 2006 | 11:22 AM
JSCspeed's Avatar
TEIN SPRINGS HERE- PM or POst for prices
Old Aug 8, 2006 | 01:52 PM
Chinxican420's Avatar
How much would they cost for a 06 G35 Coupe? Also which ones do you think are better? Pros and cons? Between the hotchicks and tien.
Thanks!
Old Aug 9, 2006 | 12:01 AM
shimmy's Avatar
PM price for Tein H Tech shipped to 90067. Thanks
Old Aug 10, 2006 | 02:48 AM
kenasaki's Avatar
will these fit an 05' g35 sedan?
also how much of a drop will it give me if i put some 19s on there?
and how much for them shipped to 90807?
Old Aug 10, 2006 | 12:44 PM
JSCspeed's Avatar
Thanks!
The hotchkis is swaybars only and tein is springs and coilovers. I am going to PM you price on tein springs. Thanks Kyle
Old Aug 10, 2006 | 01:00 PM
JSCspeed's Avatar
spring fitment
Yes- here is how the fitment is on these tein springs- each has a different part number
1.Tein 03+ G35 Sedan S Tech Springs
2.Tein 03+ G35 Sedan H. Tech Springs
3.Tein 03+ G35 Coupe S. Tech Lowering Springs
4.Tein 03+ G35 Coupe H. Tech Lowering Springs
Old Aug 14, 2006 | 04:44 PM
JSCspeed's Avatar
flex and basics instock- springs too- PM for prices
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
aaron3719
Sep 29, 2015 10:12 AM
