Budget baller tire options
Old May 19, 2006 | 09:05 PM
g35brother's Avatar
Cool Budget baller tire options
So I'm new to the forum with a used 05 and my tires are feathered as heck in the front and bald in the rear. I sound like a spaceship when I come to a stop. So I've been looking into some cost effective tires for daily and then I'll probably pick up some 18s later on for autox or fun drives. Any rate, the options are listed in the poll, if you recommend other please specify. Btw, I talked toa discount tire guy today and he recommened highly against doing 245/40/19 f and 235/40/19 r, oddly he did say I could do 245/35 f and 275/35 r?? What are you guys running on the oem rims?
Old May 20, 2006 | 12:31 AM
GLuXuRy's Avatar
coupe or sedan?
Old May 20, 2006 | 10:29 AM
g35brother's Avatar
coupe
Old May 20, 2006 | 01:33 PM
g35rcr's Avatar
why would u go with a bigger tire up front?
Old May 20, 2006 | 06:02 PM
g35brother's Avatar
Edit, meant 245/40 f and 255/40 r
Old May 20, 2006 | 06:44 PM
neal540's Avatar
do 275/35 in the rear
Old May 22, 2006 | 04:57 PM
g35brother's Avatar
the 275s are pretty pricy, what about 235/35/19f and 255/35/19r in toyo t1r??
Old May 23, 2006 | 02:17 AM
redlude97's Avatar
both those are going to be too short compared to stock diameter, the correct sizes for a 35 side wall are 245/275
Old May 23, 2006 | 12:26 PM
98intrigue's Avatar
I went from Toyo T1-S tires to the Goodyear Eagle F1 GS-D3 tires. The toyo were horribly loud around cruising speeds (40-50mph). When I changed to the Goodyears, my car sounds like I'm driving a Lexus now....OK, not a Lexus, but the Goodyears are quiet!
Old May 23, 2006 | 02:30 PM
Q45tech's Avatar
RESERVE STRENGTH [load index] is much more signficant than SIZE.
Old May 23, 2006 | 02:49 PM
timbo's Avatar
You should do 245/35/19 f & 255/40/19 r. I currently have 245/35/19 f & 245/40/19 r. I wish I'd gone a little wider on the rear. 255/40/19 is maximum recommended tire size on 8.5" wide rim.
Old May 24, 2006 | 03:53 PM
g35brother's Avatar
So you're saying its ok to do 245/35 front and 275/35 rear so the overall diameter is still the same? Isn't 275 too wide for a 8.5in tire? I'm looking into Nitto NT NeoGen ZR anyone run these before?
Old May 30, 2006 | 04:35 PM
whyjay91's Avatar
Hey, did you ever run the Potenza REO50's? If so, how do the F1's compare?
Thanks. I'm looking for replacements of my stock Bridgestone REO50's and REALLY want something quieter, but with good performance.
Old May 30, 2006 | 05:20 PM
Blackbird V35's Avatar
I run the RE050 A's which are a bit different than the REO50's and i personally liked the Eagle F1 GS D3's i had on my 18's better. I think the potenzas are stickier but the F1's were much better in rain and were quieter, not to mention they arent asymmetrical so you can actually rotate them.
Old May 30, 2006 | 05:32 PM
binar's Avatar
Did you say the Goodyear wasn't unidirectional?? Really??
