Need help with 19" tires ASAP!
Old Jun 5, 2006 | 01:18 AM
  #31
papagz's Avatar
if you want 275's for the back I have some that I barely used and will give them away for real cheap. let me know!!
Old Jun 5, 2006 | 05:07 PM
  #32
g35brother's Avatar
Powashiftin, if you could post pics after you get them on that would be awesome and any fitment issues you ran into. I am going to buy the same tires as you really soon. Need to know if its ok, I hate the way the front tires look stretched with 225s
Old Jun 5, 2006 | 05:25 PM
  #33
Powashiftin's Avatar
yeah, no problem. I didn't get a chance to get to the tire place today.
I'll definitely post before/after pics.
Old Jun 7, 2006 | 12:47 PM
  #34
g35brother's Avatar
Ok so I'm exhausted from searching, whats the word with oem rims and running different tires? Why is it not recommended yet its OK if people buy wider rims and its ok then to run wider tires and not affect the VDC/ABS. A discount rep just advised me against running 245/35/19f and 255/40/19 rear because his manual says it will lead to ABS and VDC failure with stock rims? Why does this not happen if I bought 19x8 and 19x9.5 rims with respective tire sizes like 245/35/19 and 275/35/19
Old Jun 7, 2006 | 07:30 PM
  #35
I think as long as it's staggered, it's ok. I'm not 100% sure on that though.
Old Jun 10, 2006 | 10:33 PM
  #36
dream_G35's Avatar
Originally Posted by romanwarrior
the key to replacing tires with different sizes is to get close as possible to the OE tire overall diameter. you said that you are going to use your OE wheels (fr, 19x8.0 & rr, 19x8.5) and just get different tires. it seems like you want to get wider tires... since you're using your stock wheels, you can't get the same tire overall diameter as your stock tires.
Stock Tires:
225/40R19 = OD is 26.1 inches
245/40R19 = OD is 26.7 inches
+0 Up-Sizing:
245/35R19 = OD is 25.8 inches
265/35R19 = OD is 26.3 inches
Both tire sizes that I recommended are the widest you can go on 19x8.0 and 19x8.5. If you go with a lower aspect ratio on your rear tires, you speedometer reading will be way off as you increase volocity. If you want to have the same OD as your OE tire sizes, then you would have to buy wider wheels... at least 9.5-inches wide for the rear wheels to accomodate a 275/35R19 (OD is 26.6 to 26.7 inches depending on the tire manufacturer).
Hope this helps.
*so this definetely wont affect vdc, speed, abs?*
Old Jun 11, 2006 | 11:36 PM
  #37
g35brother's Avatar
From what I've calculated
245/35/19 = OD 25.8
255/40/19 = OD 27
The only thing is width isn't that far off
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
socaldavid
Sep 5, 2015 04:35 AM
