18x8.5 +40 fit on Coupe?
Old Sep 30, 2003 | 12:49 PM
99dustmagnet's Avatar
I am going to be trading in my 99' I30 for a '04 G35 Coupe 6MT in November-December. I currently have volk racing CE28n's (18x8.5 +40mm offset) on my I30. Being that the bolt pattern is the same, will the offset be ok considering the stock coupe has a +30 offset? Will there be any problems with handling, etc? Any opinions, recommendations are welcome.
Old Sep 30, 2003 | 06:37 PM
zimbo's Avatar
Re: 18x8.5 +40 fit on Coupe?
You'll have to check to see if they'll fit over the Brembos.
--Steve
Old Sep 30, 2003 | 06:43 PM
I currently have a 12.9" brembo big brake kit on my I30, considering they fit now, is it safe to assume they will fit over the coupe brembos? Will the offset be ok? +40mm vs. +30mm?
Old Sep 30, 2003 | 10:11 PM
RaySur350GT's Avatar
It should fit ok looking at the offsets and you used to have a big brake upgrade..
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
Old Oct 3, 2003 | 08:26 PM
2003z's Avatar
I've got 8.5" wide +38 and they fit just fine, so +40 will too, although you may want a spacer to push it out a little. The outer face of the wheels should stick in 4mm closer than stock 8" wheels, and 16mm closer to the strut housing on the inner side.
EnCr1pt3d
Jul 8, 2019 02:48 PM
reaper76
Aug 5, 2015 10:13 AM
teamghost
Jul 28, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
