tire / wheels could this work ?
Old Jul 13, 2006 | 03:04 AM
lawrence's Avatar
Thinking about this wheel tire combo?
http://cgi.ebay.com/ebaymotors/18-EN...QQcmdZViewItem
I have a 2004 5at sedan in brilliant silver
I think from what I have read the offset should be ok , but the tires are a bit short?
I have used the wheel / tire size calculator and came up with a 275/35/18 on the rear and a 235/40/18 on the front. True ?
Using the sedan fitment chart it looks as if I will be able to fit, but if I lower and have corrected alignment. Will I still fit or not ? maybe fit if I roll fenders?
The tires that I would most likely be using are KUMHO's ECSTA MX http://www.tirerack.com/tires/tires....Model=ECSTA+MX
I have found that the section width of the 275 is 11.1 and of the 235 is 9.6 ( that is the widest part of the tires )
So do I have this correct or am I just as confused as everyone else doing there 1st wheel upgrade ?
Old Jul 13, 2006 | 07:45 PM
lawrence's Avatar
bump
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Popes
Jul 29, 2015 05:07 PM
realtalk21
Jul 20, 2015 09:07 AM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
