Brembo squeaking?
Old Oct 3, 2003 | 09:43 PM
Kaneda's Avatar
Brembo squeaking?
With only about 100 miles on the odometer, I'm noticing my brakes have a tendency to squeak at light pressures of breaking. This squeak seems to occur most often in bumper to bumper traffic when the brakes are applied at light pressures repeatedly. Does my brakes need to break in? Or is this common with all Brembo brake systems?
Old Oct 4, 2003 | 10:24 AM
1SlowG35's Avatar
Re: Brembo squeaking?
Welcome to Brembo's!!!!
They have really soft pads that will easy braking will make some noise.
03.5 6MT CB, Aero, Prem
02 TransAm - 11.93 @ 113 All Motor
Old Oct 4, 2003 | 03:16 PM
davey2003's Avatar
yup that's normal and will go away and comeback every now and then.
Old Oct 4, 2003 | 03:35 PM
afr0puff's Avatar
Supa Dupa Moderator
Bed your brakes, you should not have this problem.
http://www.anythingbox.net
Old Oct 5, 2003 | 01:15 PM
rmeaux's Avatar
This problem has been brought up on all G35 sites. My dealership replaced the pads on my G at 3000 miles because they were still squeaking. The new pads started squeaking after about 500 miles. I don't agree with this being normal for a $40,000 car to have squeaky breaks, Brembos or no Brembos.. I have contacted Infiniti Consumer Affairs but have not been notified of what they plan on doing.
Old Oct 5, 2003 | 01:23 PM
narkotic's Avatar
I think its caused by brakedust buildup.. See how bad it gets on your wheels? It's probably covered on the rotor and pads.. that could cause the squeal...
04' G35 / 6MT / Tein Basic Coilovers
Volk 19" GT-7 Gunmetal
Old Oct 5, 2003 | 02:30 PM
afr0puff's Avatar
Supa Dupa Moderator
One more time for the people that must have missed it.
B-E-D YOUR BRAKES! This is a common problem with high performance brakes. Read up on this, do a search on this forum. Hell, check out www.brembo.com also.
Old Oct 5, 2003 | 04:22 PM
Haggis4All's Avatar
Quite right - bedding is critical. See this from Brembo:
Should new discs and pads be bedded in and if so, how?
The answer is yes, for optimum performance, any time different friction materials or discs are introduced, a bedding procedure should be carried out.
While the vehicle is stationary, pump brakes to ensure a firm pedal.
Drive the vehicle cautiously to test fit and function.
The brakes should be smooth, with no vibrations, judder, etc.
Drive the vehicle to a remote area and perform at least 30 brake applications of 3-second duration. Use light/medium deceleration with varying starting speeds. Leave at least ½ mile between each brake application.
The purpose of this procedure is to gradually increase the temperature in the components without inducing thermal shock, and to mate the brake pad and disc friction surfaces.
After the repeated stops, drive the vehicle for several miles with little or no braking in order to adequately cool the components.
After the above process is completed, the system is ready for normal use.
When the system achieves elevated brake temperatures for the first time, a slight increase in pedal travel and pedal effort may occur. After this first "fade" and proper cooling, the system will maintain its optimum performance at all temperatures.
Red '04 G35C 6MT
Old Oct 5, 2003 | 07:30 PM
RamboRami's Avatar
G35driver.com Moderator
afropuff is 100% correct guys... Bedding your brakes will stop them from squealing (at all speeds)
But there is a known issue with the brembos squealing at extremely low speeds w/ light pressure, actually its more like a loud HOWL, not a squeal.
This will go away after ~1000 miles
I havent heard mine howl since break-in, and now i am @ the 7,500 mile mark
G35c 6MT DG/Willow/HyperGround/BorlaExhaust
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
nissandrifter32
Dec 22, 2015 04:28 PM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
TNRocker
Sep 21, 2015 08:36 AM
