Offset question...
Old Jul 28, 2006 | 05:44 PM
ShwoffG35's Avatar
Offset question...
Will a 35 offset fit on my G35 coupe??
Thanks in advance.
Old Jul 28, 2006 | 06:12 PM
SilverII's Avatar
what's the width?
Old Jul 28, 2006 | 08:02 PM
Chico's Avatar
^^and tire size. Either way that offset is way too high for most set ups on the coupe. They'll be too tucked in.
Old Jul 28, 2006 | 08:09 PM
JoEY C's Avatar
agreed...def. be tucked in no matter what the width of the wheels are...go with a lower offset
Old Jul 29, 2006 | 12:41 AM
ShwoffG35's Avatar
9.5 width...with a 275 tire.
Old Jul 29, 2006 | 12:54 AM
Zerk's Avatar
35 offset on 9.5/275? This offset would be way too conservative. If you're looking for a look flush with the fenders you need offsets in the low 20s. Also the tire size may be a little wide for the wheel.
Old Jul 29, 2006 | 01:02 AM
GTR_Boy's Avatar
+35mm should fit. But it depends if you have Brembos or a BBK, they might or might not fit. But weirdly, I bought a set of 17" snow rims with a +38mm offset during a test fitting and they actually CLEAR my Brembo front calipers due to the arc'ed design of the spokes. So I guess it depends on the design of your wheels. I'm guessing you've got a set of rims lined up but just needed to confirm if it will fit?
If not, and you are still shopping around, then I would recommend an offset in the mid +20's. You will be much happier than a +35 offset because it will look more aggressive (i.e. being more flushed with body). +35 will give you a more tucked look. Depends what type of look you are going for.
Old Jul 29, 2006 | 01:07 AM
GTR_Boy's Avatar
Actually 275's will fit perfectly for a 9.5 width wheel and giving some rim protection too. My 275's are quite stretched on my 10.5 wheels, doesn't quite cover the entire width either, and not enough rim protection. But the +35 offset is definitely too conservative.
Old Jul 29, 2006 | 01:53 AM
Chico's Avatar
...to be flushed with the fenders you will need a 15mm spacer which = +20 offset. BTW, 275 on a 9.5" wheel is the perfect tire size.
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
