What psi to run on 35series tires
Old Aug 9, 2006 | 02:23 PM
g35brother's Avatar
Like the title says, I've searched and the answer seems to vary. Right now I'm running 38ish psi on 245/35/19 tires on the front rims. I want to go lower closer to the 35psi rating on the car but it seems like at 38psi cold there's barely an inch of tire between the rim and the ground! Should I be jaking up my psi btw I am running Falken FK-452s
Old Aug 10, 2006 | 01:16 AM
skeleton_cru's Avatar
Sedan
No, that should be fine. I run 36 psi on my 245/40/19 tires.
Old Aug 10, 2006 | 01:25 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
I run the tires on all my cars at 35psi. Unless you have an LT tire you dont need more than 35.
-GP-
Old Aug 10, 2006 | 01:27 AM
Andy2434's Avatar
I'm running 35 to 36 psi on 255/285/35 x 19's.
Old Aug 10, 2006 | 01:28 AM
DHCrocks's Avatar
I'm running 38psi on my 255/35/19 tire. seems to be ok, like you I rather have a little bit more air in the tire since it's such a low profile.
Old Aug 10, 2006 | 04:06 AM
GReddySetGO's Avatar
I run 34psi.
Old Aug 10, 2006 | 11:43 AM
truplay8's Avatar
THE BATMOBILE
35.
Old Aug 10, 2006 | 12:07 PM
Brando's Avatar
Mine seem to wear much more even at 38 f & r.
At 35, the inside edges started to wear first.
Old Aug 10, 2006 | 08:35 PM
^ Fix your camber and it won't be a problem.
GBoy
The Q - Spot
Sep 5, 2015 03:15 AM
derres
Aug 28, 2015 03:27 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
joedaddy1
Jul 28, 2015 02:58 PM
