Bumpy Ride
Old Aug 10, 2006 | 06:45 PM
Kidcane's Avatar
Bumpy Ride
So I spent about $4500 on wheels and tires and my car rides way worse than it did with OEM wheels. When I get to about 80-85 I get a good amount of vibration. What can I do to get rid of it?
Old Aug 10, 2006 | 06:59 PM
drunkin master's Avatar
be more specific. What size wheels and what is your tire size? Your ride will get harsher if you have lower profiles. If you have 20's then deff. you will feel a difference. Do you have spacers? How does it feel like? is it just vibration or is your steering wheels going left to right? You might have a bad balance on the wheels and tires. Is the vibration there when you brake? If so it could be that you need an alighnment. I hope you did get one after you changed out your wheels.
Old Aug 10, 2006 | 08:13 PM
BLacK_G35_CouPe's Avatar
i had the same problem...anythin under 70 mphs it was smooth...than over that it was bumpy as hell...get an alignment...if u still havin problems...idk wut to tell u
Old Aug 11, 2006 | 09:45 AM
350_Z's Avatar
Same problem here, just got new rims/tires. Get some Hubcentric rings and an alignment and it will be smooth again.
Old Aug 11, 2006 | 11:18 AM
truplay8's Avatar
THE BATMOBILE
get an alignment
Old Aug 11, 2006 | 06:30 PM
Kidcane's Avatar
245/35/19 front and 275/35/19 rear. Staggered with, I believe 7mm spacers so they would clear my Brembos with Rotora rotors. I thought alignment only was if it pulled left or right. No problems there. And not when I brake.
Some guy was saying something about getting my tires trued? I guess they spin them and nock off and small bumps or imperfections in the tire. Anybody know about that?
Old Aug 12, 2006 | 11:46 AM
reggiek's Avatar
Like others have said, sounds like you just need some hubcentric rings. They work wonders.
KruZZe
Feb 27, 2023 05:04 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
prinny
Nov 22, 2015 11:07 PM
Fox843
Nov 7, 2015 05:43 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
