Offsets = WHOA!
Old Aug 27, 2006 | 07:52 PM
Oki-the-Nawa!'s Avatar
do spinners come with those reverse wheels?
Old Jan 16, 2007 | 06:19 PM
roneski's Avatar
Devil's Advocate
Had a few PMs asking about how they worked out. They worked out great. I did have to roll the rear fenders sitting on Tein Flex so it's a custom drop.
Old Jan 17, 2007 | 09:28 AM
dream_G35's Avatar
what size tires did you run? i have the same wheels/offset on 285's
Old Jan 17, 2007 | 09:48 AM
Mark350GT's Avatar
looks awesome!
Old Jan 17, 2007 | 10:20 AM
Ralph0064's Avatar
wow. great job! that looks awsome!
Old Jan 17, 2007 | 11:07 AM
roneski's Avatar
Devil's Advocate
Running FK452 275/35 19s in the rear, I'm not sure if I ran 245 or 255 in the front.
Old Jan 17, 2007 | 01:36 PM
GEE35FX's Avatar
Very, very nice. Looks awesome .
Old Jan 17, 2007 | 02:12 PM
JOKER's Avatar
CLUB MODERATOR
sick rims
Old Jan 17, 2007 | 02:17 PM
Hi-TechG35's Avatar
Just get some longer wheel studs to stop from snapping your stock ones if you have'nt already. You'll be fine.
Old Jan 17, 2007 | 02:41 PM
silvernole12's Avatar
Originally Posted by imalazeeass
those are the best offsets for the winnings.. imo you either go really aggressive or keep your stock rims
amen lol
Old Jan 17, 2007 | 04:19 PM
ksig113's Avatar
man that looks hot...great choice.
Old Jan 17, 2007 | 04:24 PM
Jeff92se's Avatar
Red Card Crew
Roneski. May I ask how you jacked up the front using a normal floor jack? Did you rig some type of spacer adaptor or something?
Old Jan 17, 2007 | 04:53 PM
roneski's Avatar
Devil's Advocate
The floor jack in the pic is a low clearance jack from Summit Racing.
http://store.summitracing.com/partde...5&autoview=sku
My car is just high enough to use it. I also have a Craftsman racing jack that works pretty good. I've worked on a friends G that has a Kenstyle kit and is lowered. In his case I was able to slide the jack under the skirt but couldn't lift because the jack arm contacted the kit before it got to the jack point. In his case I did have to get the head of the jack a little higher using an old psychology book.
Old Jan 17, 2007 | 04:56 PM
Jeff92se's Avatar
Red Card Crew
Thanks but I was referring to how you jack up the car right there w/o munching up the oem jack point. ie.. it has that lip that requires something with a slit in it. ie.. like the oem jack has.
Old Jan 17, 2007 | 05:03 PM
  #30
roneski's Avatar
Devil's Advocate
Ahhh... gotcha. That particular jack does have a rubber pad on the head. I haven't had a problem with it screwing up the jack point. The Craftsman jack on the other hand will tend to chew it up a little.
Someone does make a slotted adapter, but I don't have one. I'll see if I can find a link.
